- Feb 26, 2006
- Barnegat, NJ
http://www.anandtech.com/mb/showdoc.aspx?i=2820&p=2
Sorry if this is a repost.
Basic Features: ASUS P5NSLI
ASUS P5NSLI Specifications
CPU Interface: LGA775-based Pentium 4, Pentium 4 XE, Celeron D,
Pentium D, and Core 2 Duo processors.
Chipset: NVIDIA nForce 570SLI - SPP (C19-A3)
NVIDIA nForce 570SLI - MCP (MCP51-A2)
Front Side Bus: 1066 / 800 / 533 MHz
Front Side Bus Speeds: Auto, 533MHz ~ 1600MHz in 1MHz increments
Memory Speeds: Auto, 400MHz ~ 1200MHz in 1MHz increments
Memory Timings: Auto, CAS, tRCD, tRP, tRAS, tRC, Command Rate
PCI Bus Speeds: Fixed
PCI Express Bus Speeds: Default, 100MHz ~ 150MHz in 1MHz increments
Set Processor Multiplier: Auto, (1X step increments for EE or X series)
LDT Multipliers: 1x, 2x, 3x, 3.5x, 4x, 5x
Core Voltage: Auto, 0.8375V to 1.6000V (in 0.0125V increments).
DRAM Voltage: Auto, 1.8V to 2.1V (in 0.1V increments)
SPP Chipset Voltage: 1.4V. 1.5V
CPU Termination: 1.25V, 1.35V
Memory Slots: (4) x DIMM, max. 4GB per DIMM
max. 16GB total system memory
DDR2 667/533, non-ECC, unbuffered memory
Expansion Slots: (2) x PCI-E X16 (operates in X8+X8 mode for SLI)
(3) x PCI-E X1
(2) x PCI 2.3
Onboard SATA: NVIDIA nForce 570SLI:
(4) x SATA II
Onboard IDE: NVIDIA nForce 570SLI:
(2) x UltraDMA 133/100/66/33
SATA/IDE RAID: NVIDIA nForce 570SLI:
(4) x SATA II
RAID 0, RAID 1, RAID 0+1, RAID 5
Onboard USB2.0: (8) USB2.0 ports
Onboard LAN: Marvell 88E8001 PCI 10/100/1000Mb/s Ethernet LAN
Onboard Audio: ADI 1986A, 6-channel capable HD Audio
Power Connectors: 24-pin ATX
4-pin ATX 12V
Back Panel I/O Ports: 1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel (LPT)
1 x Serial (COM 1)
1 x S/PDIF Coaxial Out
1 x Audio I/O Panel
1 x RJ45
4 x USB
Features: AI Tuning - Manual, Auto, Standard, AI Overclock - 9 options
System Clock Mode - CPU only, Memory Only, CPU/Memory
BIOS: Award 0601
