- May 19, 2005
Checked my stats and my gpu folding keeps spitting this error out. I haven't changed any settings. It was running fine. Folding on a GTX260.
I have tried deleteing cores and hasn't fixed it. Restarted the computer also besides pausing/restarting the client. Running V7. Any ideas on how to fix it?
Here is my log file.
Code:
*********************** Log Started 2012-12-08T16:48:54Z ***********************
16:48:54:************************* Folding@home Client *************************
16:48:54: Website: http://folding.stanford.edu/
16:48:54: Copyright: (c) 2009-2012 Stanford University
16:48:54: Author: Joseph Coffland <[email protected]>
16:48:54: Args: --lifeline 3376 --command-port=36330
16:48:54: Config: C:/Users/Mike/AppData/Roaming/FAHClient/config.xml
16:48:54:******************************** Build ********************************
16:48:54: Version: 7.2.9
16:48:54: Date: Oct 3 2012
16:48:54: Time: 18:05:48
16:48:54: SVN Rev: 3578
16:48:54: Branch: fah/trunk/client
16:48:54: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:48:54: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:48:54: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:48:54: Platform: win32 XP
16:48:54: Bits: 32
16:48:54: Mode: Release
16:48:54:******************************* System ********************************
16:48:54: CPU: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
16:48:54: CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
16:48:54: CPUs: 2
16:48:54: Memory: 4.00GiB
16:48:54: Free Memory: 2.46GiB
16:48:54: Threads: WINDOWS_THREADS
16:48:54: On Battery: false
16:48:54: UTC offset: -8
16:48:54: PID: 3252
16:48:54: CWD: C:/Users/Mike/AppData/Roaming/FAHClient
16:48:54: OS: Windows 7 Ultimate
16:48:54: OS Arch: AMD64
16:48:54: GPUs: 1
16:48:54: GPU 0: NVIDIA:1 GT200 [GeForce GTX 260]
16:48:54: CUDA: 1.3
16:48:54: CUDA Driver: 5000
16:48:54:Win32 Service: false
16:48:54:***********************************************************************
16:48:54:<config>
16:48:54: <service-description v='Folding@home Client'/>
16:48:54: <service-restart v='true'/>
16:48:54: <service-restart-delay v='5000'/>
16:48:54:
16:48:54: <!-- Client Control -->
16:48:54: <cycle-rate v='4'/>
16:48:54: <cycles v='-1'/>
16:48:54: <data-directory v='.'/>
16:48:54: <disable-project-lookup v='false'/>
16:48:54: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
16:48:54: <exit-when-done v='false'/>
16:48:54: <threads v='4'/>
16:48:54:
16:48:54: <!-- Configuration -->
16:48:54: <config-rotate v='true'/>
16:48:54: <config-rotate-dir v='configs'/>
16:48:54: <config-rotate-max v='16'/>
16:48:54:
16:48:54: <!-- Debugging -->
16:48:54: <assignment-servers>
16:48:54: assign3.stanford.edu:8080 assign4.stanford.edu:80
16:48:54: </assignment-servers>
16:48:54: <capture-directory v='capture'/>
16:48:54: <capture-sockets v='false'/>
16:48:54: <debug-sockets v='false'/>
16:48:54: <exception-locations v='true'/>
16:48:54: <gpu-assignment-servers>
16:48:54: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
16:48:54: </gpu-assignment-servers>
16:48:54: <stack-traces v='false'/>
16:48:54:
16:48:54: <!-- Error Handling -->
16:48:54: <max-slot-errors v='5'/>
16:48:54: <max-unit-errors v='5'/>
16:48:54:
16:48:54: <!-- FahCore Control -->
16:48:54: <checkpoint v='15'/>
16:48:54: <core-dir v='cores'/>
16:48:54: <core-priority v='low'/>
16:48:54: <cpu-affinity v='false'/>
16:48:54: <cpu-usage v='100'/>
16:48:54: <no-assembly v='false'/>
16:48:54:
16:48:54: <!-- Folding Slot Configuration -->
16:48:54: <cause-pref v='ANY'/>
16:48:54: <client-subtype v='STDCLI'/>
16:48:54: <client-type v='normal'/>
16:48:54: <cpu-species v='X86_PENTIUM_II'/>
16:48:54: <cpu-type v='AMD64'/>
16:48:54: <cpus v='-1'/>
16:48:54: <cuda-index v='0'/>
16:48:54: <gpu v='true'/>
16:48:54: <gpu-usage v='100'/>
16:48:54: <max-packet-size v='normal'/>
16:48:54: <opencl-index v='0'/>
16:48:54: <os-species v='UNKNOWN'/>
16:48:54: <os-type v='WIN32'/>
16:48:54: <project-key v='0'/>
16:48:54: <smp v='true'/>
16:48:54:
16:48:54: <!-- Logging -->
16:48:54: <log v='log.txt'/>
16:48:54: <log-color v='false'/>
16:48:54: <log-crlf v='true'/>
16:48:54: <log-date v='false'/>
16:48:54: <log-date-periodically v='21600'/>
16:48:54: <log-debug v='true'/>
16:48:54: <log-domain v='false'/>
16:48:54: <log-header v='true'/>
16:48:54: <log-level v='true'/>
16:48:54: <log-no-info-header v='true'/>
16:48:54: <log-redirect v='false'/>
16:48:54: <log-rotate v='true'/>
16:48:54: <log-rotate-dir v='logs'/>
16:48:54: <log-rotate-max v='16'/>
16:48:54: <log-short-level v='false'/>
16:48:54: <log-simple-domains v='true'/>
16:48:54: <log-thread-id v='false'/>
16:48:54: <log-thread-prefix v='true'/>
16:48:54: <log-time v='true'/>
16:48:54: <log-to-screen v='true'/>
16:48:54: <log-truncate v='false'/>
16:48:54: <verbosity v='5'/>
16:48:54:
16:48:54: <!-- Network -->
16:48:54: <proxy v=':8080'/>
16:48:54: <proxy-enable v='false'/>
16:48:54: <proxy-pass v=''/>
16:48:54: <proxy-user v=''/>
16:48:54:
16:48:54: <!-- Process Control -->
16:48:54: <child v='false'/>
16:48:54: <daemon v='false'/>
16:48:54: <pid v='false'/>
16:48:54: <pid-file v='Folding@home Client.pid'/>
16:48:54: <respawn v='false'/>
16:48:54: <service v='false'/>
16:48:54:
16:48:54: <!-- Remote Command Server -->
16:48:54: <command-address v='0.0.0.0'/>
16:48:54: <command-allow v='127.0.0.1'/>
16:48:54: <command-allow-no-pass v='127.0.0.1'/>
16:48:54: <command-deny v='0.0.0.0/0'/>
16:48:54: <command-deny-no-pass v='0.0.0.0/0'/>
16:48:54: <command-port v='36330'/>
16:48:54:
16:48:54: <!-- Slot Control -->
16:48:54: <max-shutdown-wait v='60'/>
16:48:54: <pause-on-battery v='false'/>
16:48:54: <pause-on-start v='false'/>
16:48:54:
16:48:54: <!-- User Information -->
16:48:54: <machine-id v='0'/>
16:48:54: <passkey v='********************************'/>
16:48:54: <team v='32'/>
16:48:54: <user v='jacknsally'/>
16:48:54:
16:48:54: <!-- Work Unit Control -->
16:48:54: <dump-after-deadline v='true'/>
16:48:54: <max-queue v='16'/>
16:48:54: <max-units v='0'/>
16:48:54: <next-unit-percentage v='99'/>
16:48:54:
16:48:54: <!-- Folding Slots -->
16:48:54: <slot id='0' type='GPU'/>
16:48:54: <slot id='1' type='SMP'/>
16:48:54:</config>
16:48:54:Trying to access database...
16:48:54:Successfully acquired database lock
16:48:54:Enabled folding slot 00: READY gpu:0:"GT200 [GeForce GTX 260]"
16:48:54:Enabled folding slot 01: READY smp:2
16:48:54:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
16:48:54:Started thread 3 on PID 3252
16:48:54:Started thread 1 on PID 3252
16:48:54:Started thread 6 on PID 3252
16:48:54:Started thread 5 on PID 3252
16:48:54:Started thread 4 on PID 3252
16:48:54:WU01:FS00:Connecting to www.stanford.edu:80
16:48:54:Started thread 7 on PID 3252
16:48:54:WU01:FS00:FahCore 15: Downloading 1.48MiB
16:48:56:WU01:FS00:FahCore 15: Download complete
16:48:56:WU01:FS00:Valid core signature
16:48:56:WU01:FS00:Unpacked 4.47MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe
16:48:56:WU01:FS00:Starting
16:48:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
16:48:56:WU01:FS00:Started FahCore on PID 3532
16:48:56:Started thread 8 on PID 3252
16:48:56:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
16:48:56:Started thread 9 on PID 3252
16:48:57:WU01:FS00:Core PID:3664
16:48:57:WU01:FS00:FahCore 0x15 started
16:48:57:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
16:49:54:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
16:49:54:WU01:FS00:Connecting to www.stanford.edu:80
16:49:54:WU01:FS00:FahCore 15: Downloading 1.48MiB
16:49:56:WU01:FS00:FahCore 15: Download complete
16:49:56:WU01:FS00:Valid core signature
16:49:56:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
16:49:56:WU01:FS00:Starting
16:49:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
16:49:56:WU01:FS00:Started FahCore on PID 3808
16:49:56:Started thread 10 on PID 3252
16:49:56:WU01:FS00:Core PID:3952
16:49:56:WU01:FS00:FahCore 0x15 started
16:49:57:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
16:51:25:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
16:51:25:Started thread 11 on PID 3252
16:51:31:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
16:51:31:WU01:FS00:Connecting to www.stanford.edu:80
16:51:31:WU01:FS00:FahCore 15: Downloading 1.48MiB
16:51:33:WU01:FS00:FahCore 15: Download complete
16:51:33:WU01:FS00:Valid core signature
16:51:33:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
16:51:33:WU01:FS00:Starting
16:51:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
16:51:33:WU01:FS00:Started FahCore on PID 3860
16:51:33:Started thread 12 on PID 3252
16:51:33:WU01:FS00:Core PID:2652
16:51:33:WU01:FS00:FahCore 0x15 started
16:51:34:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
16:54:08:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
16:54:08:WU01:FS00:Connecting to www.stanford.edu:80
16:54:08:WU01:FS00:FahCore 15: Downloading 1.48MiB
16:54:11:WU01:FS00:FahCore 15: Download complete
16:54:11:WU01:FS00:Valid core signature
16:54:11:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
16:54:11:WU01:FS00:Starting
16:54:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
16:54:11:WU01:FS00:Started FahCore on PID 3848
16:54:11:Started thread 13 on PID 3252
16:54:11:WU01:FS00:Core PID:2276
16:54:11:WU01:FS00:FahCore 0x15 started
16:54:12:WU01:FS00:0x15:
16:54:12:WU01:FS00:0x15:*------------------------------*
16:54:12:WU01:FS00:0x15:Folding@Home GPU Core
16:54:12:WU01:FS00:0x15:Version 2.22 (Wed Feb 16 09:48:20 PST 2011)
16:54:12:WU01:FS00:0x15:Build host amoeba
16:54:12:WU01:FS00:0x15:Board Type NVIDIA/CUDA
16:54:12:WU01:FS00:0x15:Core 15
16:54:12:WU01:FS00:0x15:Window's signal control handler registered.
16:54:12:WU01:FS00:0x15:Preparing to commence simulation
16:54:12:WU01:FS00:0x15:- Looking at optimizations...
16:54:12:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
16:54:12:WU01:FS00:0x15:- Created dyn
16:54:12:WU01:FS00:0x15:- Files status OK
16:54:12:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:54:12:WU01:FS00:0x15:Need version 225
16:54:12:WU01:FS00:0x15:Error: Work unit read from disk is invalid
16:54:12:WU01:FS00:0x15:Folding@home Core Shutdown: CORE_OUTDATED
16:54:12:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
16:58:23:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
16:58:23:WU01:FS00:Connecting to www.stanford.edu:80
16:58:23:WU01:FS00:FahCore 15: Downloading 1.48MiB
16:58:25:WU01:FS00:FahCore 15: Download complete
16:58:25:WU01:FS00:Valid core signature
16:58:25:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
16:58:25:WU01:FS00:Starting
16:58:25:WU01:FS00:Removing old file './work/01/logfile_01-20121208-045312.txt'
16:58:25:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
16:58:25:WU01:FS00:Started FahCore on PID 3248
16:58:25:Started thread 14 on PID 3252
16:58:25:WU01:FS00:Core PID:3256
16:58:25:WU01:FS00:FahCore 0x15 started
16:58:25:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
17:05:14:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah
17:05:14:WU01:FS00:Connecting to www.stanford.edu:80
17:05:14:WU01:FS00:FahCore 15: Downloading 1.48MiB
17:05:16:WU01:FS00:FahCore 15: Download complete
17:05:16:WU01:FS00:Valid core signature
17:05:16:WARNING:WU01:FS00:FahCore has not changed since last download, aborting core update
17:05:16:WU01:FS00:Starting
17:05:16:WU01:FS00:Removing old file './work/01/logfile_01-20121208-045449.txt'
17:05:17:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 3252 -checkpoint 15 -gpu 0
17:05:17:WU01:FS00:Started FahCore on PID 1708
17:05:17:Started thread 15 on PID 3252
17:05:17:WU01:FS00:Core PID:3540
17:05:17:WU01:FS00:FahCore 0x15 started
17:05:17:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
