Correct. I specificied earlier that the CPU at 4ghz was ~200W. So with furmark load on the stock GPUs + CPU at 4Ghz = ~827W. Consider that gaming doesnt stress a CPU or GPU as much as furmark/cpu stability tests, you are looking at ~700W peak with ~675W averages.
In my 470 review, with P95 (CPU at 4Ghz) and Furmark running, I barely broke 400W peak...
The bottom line is you are fine so long as you dont get into volt modding the card. It will handle the cards and the CPU overclocked just fine. If you are benchmarking and pushing the limits, you will be darn close to 1KW which that PSU should be able to handle anyway.
Not much at all. But those numbers, as bobn pointed out do not include the CPU.Ah woops, I must've missed that part. Thanks for clearing that up
How much more different is the i7-950 and the i7-920 in efficiency?
