Here is the link to my build log:
http://www.ocforums.com/showthread.php?t=626235
Ok so i have a 120.3 cutout at the top of my cosmos 1000 case. I am mounting the rad inside and the 3 38mm scythe ultra kazes on the exterior pulling air through the rad. Now as you can see from my build log, i have put in two intake fans on the front of the case that will pulling air in across the HD bays. Now i want to mount a 120.2 GTX vertically on the face of the HD bays and have fans pulling air through the rad from the front. My problem is that this should block the lower intake fan at the bottom of the case as it will sit 38mm on the bottom of the case. My question is.... I am planning on an AMD build but may go to i7. This is a high end computer and will be overclocking to over 4Ghz if at all possible. I will run a dual GPU but not crossfire or SLI. I want to cool the GPU & CPU with these rads, but want overkill for my watercooling setup not "this will be enough to cool that" I want alot more cooling than i will need. So what 120.2 rad that is THINNER would work for this setup i want that will cool a high end GPU, or how can i get the GTX to work here? Suggestions would be appreciated...
