maybe BD FX but not PD fx.... but i agree, for budget go with Phenom2
PS: i would not change my fx for a phenom2.
i second this !
coming from a 965 myself ....
I'll take a phenom over an fx so fast it'll make your head spin.
8350=$189.00
board able to support it=$200.00
965=79.95
board to support it=$129
and clock for clock the phenom will beat bd and pd in my book.
So, what everyone is saying is phenom ll will not bottleneck a newer GPU, ie. 7870/7950?
A Core 2 Duo or Athlon X2 won't bottleneck a severely GPU-dependant title, much less anything newer / better.
But a core 2 duo or Athlon X2 would bottleneck a newer gpu. So... would that not bottleneck the entire performance of the rig and game play?
I think that "bottlenecking" is being misrepresented here, as it often is.
Given a CPU bottleneck, such as a core2 or an athlon64, a faster GPU will still get better performance than a slower GPU. Just not as much peak performance.
The bottleneck that renders a 7970 no faster than a 4870 is probably somewhere in the P3 or early P4 range.
This is apparent even in extremely GPU bound stuff like the Unigine Heaven benchmark. The top scores for all top end GPUs are all on SB/IB, because they bottleneck the GPU the least.
For CPU to not matter in benchmarks you need a GPU of ~4550 class or lower, it matters with anything higher.
Most top end GPUs can do 60FPS at 1080p even with a mid range chip driving them. Does this mean they are not bottlenecked? NO. It only means that the bottleneck isn't a problem.
The bottom line is that there isn't a magic CPU core / number / speed where suddenly a 7970/GTX680 is no longer bottlenecked, in my experience CPU always matters. Sometimes it matters more than others, but it always does.
In short, the concept of a bottleneck is the wrong way to look at it IMO. Ask instead what CPU in X price range will work best with Y games. If the CPU can't hack the game, it won't matter what GPU you have, and vice versa.
The bottom line is: Everything is bottlenecked by CPU. Whether you'll notice depends on the game.
As a compete sidenote, the OP hasn't posted since the 14th or logged on since the 19th.
I thank you sir. I didn't wanna dive too deep into it, settling on what I outlined in my post haha. I do know that Deneb isn't sufficient in modern MMO's, Planetside 2, or FSX at the very least. I didn't want to say "The GPU gets limited by the CPU once you hit 194 FPS"
There's some more obscure titles that stagger slightly on a Deneb, such as S4 League that I played on my now 8350 rig, but I can tell you that on a 6300 (And an 8350), these titles do a lot better.. Particularly with MMO's (With one going from 1-6 FPS for the first 15 seconds before jumping to 30 in cities to holding at 40-60)
I didn't notice the inactivity of the OP
My 2 cents...I had a noticeable improvement going from a 965 to my 8350 in "some" games.
Planet Side 2, War Z <--- both a work in progress mind you.
Some games simply have a lot of physics / AI to calculate on the CPU too, CPU heavy games aren't necessarily poorly coded.
