I made an inquiry yesterday at intel's official site...asking about what would be the maximum safe voltage of RAM tolerated by the i5-2500K specifically... and anyway this is the conversation:
I was quite socked to see that he said something like "sorry but that will not work, the controller will operate at 1333MHZ or not operate at all "...that means that if you use any differently MHz frequenced RAM the system will fail and not work. I mean while searching for the best DUAL RAM-kit possible for gaming use...i've never been told or read anything about that part...everyone suggested 1600 MHz ++ without any mentioning anything about that. How true is what he told me actually? I mean i'm already sure that my warranty will go void if i don't "play by these rules" ...but still if it's perfectly fine to abide these rules and use what's actually best for performance (without killing my rig and having malfunctions of course)...then the hell with that.
[email protected]: hello there
Daniel: Hello. Thank you for using the Intel Customer Support chat service. We are glad to be of service. How can I help you today?
[email protected]: well i have a question
[email protected]: regarding the voltage that socket 1155 intel i5-2500k can tolerate
[email protected]: the voltage of RAM that is...
[email protected]: what is the maximum voltage that the RAM has to be in order for the processor to be...safe
[email protected]: ?
Daniel: Since the memory controller is built into the processor, it will take a maximum of 1.5V DDR3 1066 1333 Mhz
[email protected]: what?
[email protected]: maximum of 1333 MHz of RAM ?
Daniel: correct, check the following website:
Daniel: http://ark.intel.com/Product.aspx?id=52210&code=Intel®+Core™+i5-2500K+Processor+(6M+Cache,+3.30+GHz )
[email protected]: i thought the processor was refering to gamers and pc enthusiasts in general :S
[email protected]: hmmm ok...let me ask something else then..
Daniel: go ahead
[email protected]: what happens if i use a 1.5v of higher frequency?
[email protected]: it simply won't do any difference on performance?
[email protected]: make any difference*
Daniel: you will damage the memory controller on the cpu, the system will stop working eventually
Daniel: you will cause damage to the system when using memory rated at higher voltages
[email protected]: but like i said
[email protected]: it will be 1.5v
[email protected]: the frequency alone..will be higher
[email protected]: that would still dmg the processor?
Daniel: ?
Daniel: Again,
Daniel: you can only use 1.5V, not higher or lower, plain 1.5V rated memory exclusively..
[email protected]: mate...the voltage will BE 1.5 v
[email protected]: but it will be 1600 MHz
[email protected]: or 2000 MHz
Daniel: sorry but that will not work, the controller will operate at 1333MHZ or not operate at all
Daniel: we don't recommend that , is up to the customer's risk
[email protected]: uhuh...does intel actually have a processor able to handle 2400 MHz anyway?
[email protected]: no need to point out a specific one..
Daniel: no.
[email protected]: ok ok.. well then all the companies that actually create RAMs and specifically mention that are compatible and even especially made for the 2nd generation intel processors...
[email protected]: but function at higher frequencies than the CPUs
[email protected]: what would be the point?
Daniel: I will suggest forwarding your inquiry to the different memory manufacturers.
[email protected]: uhuh..i understand
[email protected]: i ll do that
