shirker said:I thought crucial ballistix were either D9GMH or D9GKX? GMH are the best chips, but even GKX ICs are respectable in their own right, since they can usually overclock to 950, 1000
D9 chips are a term widely used to describe the ICs/memory modules that micron makes. However, a few specific "D9" models are extremely overclockable
keep in mind also that Microns binning of D9GMH and D9GKX happens at 1.8v CL5. most manufacturers that produce D9GMH/D9GKX based modules run them at 2.1v if not higher. there is a world of difference between 1.8v and 2.1v so by the time the memory even makes it to market on the modules we all use, they are about on the same playing field for the most part.Reefa_Madness said:It is generally held that GMH will scale better with voltage, but given that they are basically the same chips, just binned to different grades by Micron, I don't really know that it is a supportable assertion.
