NoL said:Well that is the point of acetone, to create max surface area at the bottom. Though people don't recommend using a lot of acetone as it will mostly imho affect pulldown times, if you must I've used a max of 5 shots of acetone in my old aluminum mousepot (now in Waffles hands) and never seen a temperature difference after the first 10 minutes.
NoL said:10lbs isn't enough? How long do you bench for!
I bench 2-3 hours and 10lbs is more than enough, it leaves me about 2-3 lbs at the end to play with.
The acetone is absolutely worth it, and different levels do perform quite differently depending on the design of the container. My chilly1 container has a bar in the center as I said. A friend and I did our best to test different levels, and got the lowest temps (by over 5 degrees) with it filled up to the top of the bar.g0dM@n said:i have a feeling that it's almost not even worth doing that...
i mean, does it make that much of a difference to have that?
i wasn't speaking of the acetone... was speaking of the "fingers" (jets)...Gautam said:The acetone is absolutely worth it, and different levels do perform quite differently depending on the design of the container. My chilly1 container has a bar in the center as I said. A friend and I did our best to test different levels, and got the lowest temps (by over 5 degrees) with it filled up to the top of the bar.
g0dM@n said:how high is that "bar"? pix plz!!!
Gautam said:My Chilly1 container has a bar in the center, about 2" tall and I think 3/8" in diameter. So basically you're heading down the right path.
Oh sure, go ahead and make a ninja edit AFTER I post. Thanks for making me look bad.g0dM@n said:i wasn't speaking of the acetone... was speaking of the "fingers" (jets)...
Epox4life said:blah blah blah
its VERY easy and does increase surface areaGautam said:Yeah, jets definitely help a lot in waterblocks as far as increasing turbulence, but I'm not sure how much that would help in this application, if at all?
But plenty seem to be doing it.
