- Oct 18, 2004
- Seattle, WA
While looking through my Catalyst Control Center profile .xml file (You can find it at Documents and Settings/"username"/Local Settings/ATI/ACE if you have CCC installed and a profile created), I found a set of values that control not just 3D clocks but 2D clocks also:
In the interest of lowering energy consumption, is there any drawback to lowering 2D clocks?
Also, it appears I can mess with the voltages as well:
For example, I can lower the 2D core clock from 50000 (500MHz) to 40000 (400MHz).<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="50000" />
<Property name="Want_2" value="62500" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="75000" />
<Property name="Want_1" value="75000" />
<Property name="Want_2" value="99300" />
Given the memory voltage values are all 0, I probably shouldn't mess with those (I have no idea why these values are 0s nor what numbers to put in here), but it looks like 2D and 3D core voltage can be modified. Anyone think this is a bad idea?<Feature name="CoreVoltageTarget_0">
<Property name="Want_0" value="1046" />
<Property name="Want_1" value="1046" />
<Property name="Want_2" value="1082" />
</Feature>
<Feature name="MemoryVoltageTarget_0">
<Property name="Want_0" value="0" />
<Property name="Want_1" value="0" />
<Property name="Want_2" value="0" />
