- Aug 28, 2010
Hello,
After viewing this post:
I gave it a try, but it seems that it doesn't work. I don't know if it has been fixed by amd.
I just want to know if it works for you guys or if you got another solution to force the card to idle at lower speed.
Thanks for you help.
BTW, I use catalysm 10.10...
Bored of 3D clocks in 2D mode? Then fix it!
1_Open CCC and choose Overdrive tab,Unlock the Settings(by Clicking on the " Gold Key" Icon)
2_Go top Options,Profile and choose Profile Manager.
3_In the Composition tab,choose "The following settings" and in the "ATI Radeon HD x.x.x.x series"make sure only ATi Overdrive is checked.
Now enter a Profile name,then save and close it(Do not activate).
4_Go to C:\Users\Your UserName\AppData\Local\ATI\ACE\Profiles (Its hidden so make sure you unlock hidden files and folders)
5_Open the profile with wordpad and edit the values:
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="15700" />
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="30000" />)
and for the second card (If any):
<Feature name="CoreClockTarget_1">
<Feature name="MemoryClockTarget_1">
Save the changes and close.
6_Open CCC,in options tab go to profiles,profile manager and choose the profile that you saved before and then click on Activate and close.
Now your cards will idle @ 157/300
Link: http://www.overclock.net/ati/784861-ati-radeon-hd-5870-refuses-idle.html
