- Aug 28, 2010
Hello,
After viewing this post:
I gave it a try, but it seems that it doesn't work. I don't know if it has been fixed by amd.
I just want to know if it works for you guys or if you got another solution to force the card to idle at lower speed.
BTW, I use catalysm 10.10...
This is a repost. I know it doesn't work anymore after reading some forum post.
I am still wondering if there's another solution than flashing the card with the desired value (XFX product, warranty is awesome).
Thanks for your help!
Bored of 3D clocks in 2D mode? Then fix it!
1_Open CCC and choose Overdrive tab,Unlock the Settings(by Clicking on the " Gold Key" Icon)
2_Go top Options,Profile and choose Profile Manager.
3_In the Composition tab,choose "The following settings" and in the "ATI Radeon HD x.x.x.x series"make sure only ATi Overdrive is checked.
Now enter a Profile name,then save and close it(Do not activate).
4_Go to C:\Users\Your UserName\AppData\Local\ATI\ACE\Profiles (Its hidden so make sure you unlock hidden files and folders)
5_Open the profile with wordpad and edit the values:
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="15700" />
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="30000" />)
and for the second card (If any):
<Feature name="CoreClockTarget_1">
<Feature name="MemoryClockTarget_1">
Save the changes and close.
6_Open CCC,in options tab go to profiles,profile manager and choose the profile that you saved before and then click on Activate and close.
Now your cards will idle @ 157/300
Link: http://www.overclock.net/ati/784861-ati-radeon-hd-5870-refuses-idle.html
