- Oct 11, 2005
- Tau'ri
His comes first and is about performance. With an option for price/performance
Mine comes second and is about price/performance/quietness.
So far from my research there really isnt that much difference in price/performance except for the radiator. Thermochill for best. GTS for second best for much much less (which works for me as i was thinking a GTS anyway because I wouldnt have to apint the rad)
ANywho
Performance
Price/Performance
Other Stuff for both Catagory
Tubing clamps and res vs Tline.. I prefer Res although harder to fill / bleed... means more water and thats never bad.
No particulare recommendation for res... if he has room a 2x 5.25" or eve na 3x T line is cheap with hardware parts.. .looks crappy though (imho)
Go with:Microres
Tubing, tygon = best or masterkleer = second (or is it masterclear) 1/2" I(D or 7/16"
Go with: Masterclear
Clamps = best Thoses screw on jobbies, dont know what they are called so cant find them,, but I think that would be the best. Price/Performance= cheap *** worm drives. (the metal screw driven things)
Go with: Standard Worm Drives
Those hose ani-kninking things
The cheap plastic ones I found looked like crap and the first WC package I got had them... they sucked.. Did there job but once on they stayed on (I didnt put them on so I dont know how easy that was) I know trying to pull htem off they just shattered. I saw some metall rings that looked great...dont know what they are though
Go With: Nothing thick wall tubing doesnt need them
Added (cant beleive I forgot to mention this originally)
Fans
Go with: Yate Loon D12SL-12
MY personal WC kit will be the least expensive of the two...
Go with: 355 pump barb and bridge modded, yates already mentioned or the lighted ones, MCR320 Tubing :?
Tips suggestions? (Oh I looked for Iwaki pumps online... and couldnt find any, only thing I found was an XS link that led to parts... I thought Iwaki was trhe flow/head king... but figuring it out is a little beyond me i guess
ANywho
Performance
- Thermochill 120.3
- MCP355 with alphacooltop and 1/2" barbs or the 655 (or that Iwaki in the Classies)
- Apogee GTX
Price/Performance
Black Ice GTS (any color)Swiftech MCR320- mcp355 unmodded
- Fuzion waterblock (better for mulitblock systems, and supposedly has a bling factor although I didnt look at pics just stats and prices)
Go with:Microres
Fans
