g0dM@n said:yes, i'm on the jumper.
i'm thinking about the J19 mod or w/e it's called, but does that really fix the potential issue?
situman said:Do you really want to stick with a "killer" mobo? Wouldn't you have a better peace of mind with something less lethal to your other hardwares? Try an Epox if ur looking to move away from DFI.
Rattle said:there's nothing wrong with the DFI mobo, if you use the 4v jumper with BH5 and high voltage, your gonna lose PSU's and ram and maybe the board, its been said not to use it in the past as far as I'm aware of.
Meathead said:So then what are we supposed to do? If this were any other company, they'd recall their boards. I knew there were problems when I got my DFI board but I never read once that components were in danger of randomly failing because of it.
Meathead said:Read what you just typed. Theres nothing wrong with the mobo except if you use the 4v jumper it could take out other components or itself? That sounds like one serious problem to me.
g0dM@n said:Yeah, well it WAS solid until now.
LOL... I've had the 8RDA+ as well.RJARRRPCGP said:The motherboard may have bad caps, even if not as likely as with an Epox EP-8RDA+ motherboard.
Bad caps have been reported to cause the same problem that you have.
Possible, even if not bulging. Electrolyte may have been leaked on to the motherboard.
http://badcaps.net
Rattle said:not if your aware of it and dont use it lol
Meathead said:Yea I understand and thanks for the Good lucks but it just kind of makes me mad that DFI is making money;/ I wouldn't mind seeing them get ran into the ground.
I saw a explicit warning in the manual and decided I'd never try it. Too risky. But with the right memory and good cooling, an awesome OC would be possible for some one with the skills and stones to succeed. It's kinda like the gas pedal in a hot sports car. Someone could put the pedal to the metal and wipe himself out. Should they put a governer in all sports cars to prevent them going any faster than 55MPH?Meathead said:It shouldn't be there if its a feature that helps sell the board and is causing major problems. Also I don't see any warnings on DFI's site.
