Dns Help!!!
HelpfromU
Hello Kind Person,
I'm attempting to setup DNS for a Web Server, beginning with the core
Domain Name and files, paving the way for additional Virtual Hosts. In the
past few days my research has included: Craig Hunt's TCP/IP Network
Administration, Albitz and Liu's DNS and BIND, numerous web pages,
(including www.isc.org/bind8/index.html), this news group, the Linux DNS
howto, and the documentation delivered with the Bind 8.1.1 distribution
(bind-8.1.1/misc/{dns-setup, FAQ.1of2, FAQ.2of2).
Net result: I'm lost!!
A couple questions and then I'll list the contents of my /etc/named.conf,
and my /var/named
1. In the new Bind 8 /etc/named.conf, do the terms Master and Slave
replace the named.boot terms Primary and Secondary?
2. My co-location ISP is handling the reverse files, am I right in
thinking that I need only 3 files for a basic web-serving DNS? I.e.
/etc/named.conf, /var/named/127.0.0 and /var/named/K4AZL.NET/db.k4azl?
Here is the contents of the /etc/named.conf file:
options {
directory "/var/named";
logging {
category lame-servers { null; };
category cname { null; };
zone "k4azl.net" in {
type master;
file "K4AZL.NET/db.k4azl";
*zone "nothingspecial.com" in {
* type master;
* file "NOTHINGSPECIAL.COM/db.nothingspecial";
zone "."in{
type hint;
file "root.cache";
zone "0.0.127.in-addr.arpa"in{
type master;
file "127.0.0";
Here is the contents of the /var/named/127.0.0 file:
@ IN SOA yompy.k4azl.net. hostfriend.yopmy.k4azl.net. (
4 ; Serial
28800 ; Refresh
7200 ; Retry
604800 ; Expire
86400) ; Minimum TTL
IN NS yompy.k4azl.net.
1 IN PTR localhost.
And here is the contents of the /var/named/K4AZL.NET/db.k4azl file:
@ IN SOA yompy.k4azl.net. hostfriend.yompy.k4azl.net. (
97120502 ; serial
3600 ; refresh (1 hour)
300 ; retry (5 mins)
3600000 ; expire (41 days 16 hours)
3600 ) ; minimum (1 hour)
IN NS 209.24.233.12
IN NS 206.86.0.21
IN NS 206.86.8.69
IN NS 206.86.8.14
localhost IN A 127.0.0.1
yompy IN A 209.24.233.12
With these configuration files, using nslookup, I get the following:
yompy:/var/named/K4AZL.NET# nslookup
Default Server: localhost
Address: 127.0.0.1
> 127.0.0.1
Server: localhost
Address: 127.0.0.1
Address: 127.0.0.1
> k4azl.net
Server: localhost
Address: 127.0.0.1
*** localhost can't find k4azl.net: Non-existent host/domain
Many thanks for any help you can offer.
