- Jun 30, 2003
- Columbus, Ohio
The windows registry is possibly the worst idea ever. I think it's one of the top five reasons why Windows is a bad operating system.
I disagree. I think that, on paper, a central repository of configuration information is a Good Idea, but in practice, it just doesn't work. I'd rather have a whole bunch of .conf files than how the registry is on Windows.Chris_F said:The windows registry is possibly the worst idea ever. I think it's one of the top five reasons why Windows is a bad operating system.
Captain Newbie said:I disagree. I think that, on paper, a central repository of configuration information is a Good Idea, but in practice, it just doesn't work. I'd rather have a whole bunch of .conf files than how the registry is on Windows.
Quailane said:One thing that helps is the spybot S&D resident. Everytime something tries to make a registry change it asks if you want to allow it. Most of it I deny because it is just crap.
This comes back to an issue I outlined above--Windows was never originally built with any notion of restricted access or priveleges. If you wisely restricted access to a registry, it'd be better. (But they don't, so it's a moot point.)Chris_F said:The problem is that the registry is a crucial part of the operating system and that ANY program can do WHATEVER it wants to it. That's what causes the registry to get ****ed so much.
When you install a program it likes to make a whole bunch of edits to the registry and then when you uninstall that program it doesn't fix the registry.
That's why linux (or just about any other OS) is so much better IMO.
Chris_F said:Windows is very susceptible to viruses and spyware. The windows registry is susceptible to getting ****ed by viruses and when you install and uninstall a lot of software. Before you know it windows takes 5x longer to load then it did before, task manager shows you have 200 processes running and you can't even open a program without the computer bluescreening.
It's the same story every time.
If you know what your doing you can try your best to maintain windows but you usually cave in and decide to wipe the dang thing and reinstall it.
jajmon said:ok - I 'skimmed' thru this post. I maintain 4 XP boxes in my houshold and 2@work, along with w2k and w2k3 servers@work. But the jist of this thread is the 'home' system as I gather. As far as those that posted as to having to re-install xp every 1-2months - you have a problem. The 4 xp systems I have at home (actually 2@college, 2@home) have been running for THREE years w/o ANY issues. NO need to REINSTALL EVERY 1-2 MONTHS. So what does that tell you? If you can't keep a stable install - then you are doing something wrong. I think the problem, like others have posted, is the the USER. Clicky Clicky on everything, using IE and OE, 'what's a antivirus program' , not having virus defs up to date, not having their OS patched (what is windows update?)OH I want to see pictures of so and so from an email, click here. Like someone posted about buying a refrigerater and plugging it in and just having it work, that is just the type of mentality that the 'common' pc user expects. They are not educated or care to be. they just go on their merry way an clicky clicky and all of a sudden their pc is messed up, to the point that many actually thro them in the trash and buy another, cause the other one was 'broken' and a POS because of Windows.
To end this, if you have to install windows every 1-2 months - YOU HAVE A PROBLEM
PS - I didn't vote because there wasn't section for 'Stupid End User'
PSS - I run Linux and BSD also for those that are campaining for those OS's
MRD said:It's mostly basic design issues. Windows simply is not designed for long term stability. *snipped*
You can also argue about what is user error. I do think that a very savvy user can maintain a fairly stable Win 2K/XP box, but the level of effort and knowledge required makes me wonder at what point it's user error and what point it's just poor design. *snipped* Windows is sort of like that. An OS shouldn't be that difficult to make secure/stable, and should not be that insecure/unstable by default.
Not necessarily. There are enough security holes that as long as it had an internet connection it could mess it's self up on it's own.if left alone as long as the HDD didnt fall apart then the O/S would last many ,many,many years right?
Chris_F said:First of all, I over exaggerated my post. Second of all, I didn't say I had to reformat 1-2 month because it became unstable, but rather to keep windows running just as good as a newly installed version of windows.
If you have a install that's been running for 3 years and is "stable", good for you. Here's a cookie. Chances are there's a lot more that's wrong with it then you know. "Stable" could mean anything. You could have hordes of spyware, a tattered registry and an overall slow system and it still be "stable".
Like I said before you don't have that problem with something like Linux. You could run it for years and still have the same exact operating system you had before.
Most if not all my problems with windows XP has been through damage done by poorly written third party apps. Windows also dosen't make it easy to find the problems either so you are pretty much on your own.Super Nade said:Mate,
I made this poll with an ernest belief that I'm not a stupid end user. So the whole virus/spyware/external crap issue doesn't affect me. As I have mentioned in an earlier post, system stability was tested on a seperate drive meant for this very purpose. Also, any member of these forums is intelligent enough not get themselves infected by spyware and take basic precautions. So those issues are irrelevent AFA I'm concerned.
it is human error EVERY TIME
