- Jan 2, 2004
I would like to change the NT/XP BSOD on my Windows box to say "FLAGRANT ERROR...I don't know what you did moron, but you sure screwed everything up!"
MRD said:Holy crap. That's unbelievable. I thought it was bad when spybot found 5 tracking cookies.
AngelfireUk83 said:Since I built this system up last June time it's never stayed on has XP Pro for more than 4 months without having a problem. Then a re-install is all I can do I think now I can't do it anymore cause I've over used the Product Key but since September it's been OK. Even since I've OCed it's been stable sometimes it takes a while to load up everything when I log in but I'm happy (So Far).
Not quite true; I've had good luck calling Microsoft's gaming division before. But their OS division sucks.MRD said:A call to Microsoft is never painless.
MRD said:Windows ME must be reinstalled every 12 hours or it becomes unusable.
That was a horrible product.
Windows is simply poorly designed and is not suitably designed for long-term consistent uptime and long-term efficient use.
I didn't think it was that bad. I installed it and it worked fine for me. However I found that ME had lousy legacy and even recent driver support. The way I overcame that was to install 98SE then ME as an upgrade. Then it worked OK. I still reinstalled 98 as I saw no real advantage to MElite over 98lite. The extra goodies were in XPpro/home anyway and that was better than either DOS based OS.MRD said:Windows ME must be reinstalled every 12 hours or it becomes unusable.
