1. What range would you say are decent\acceptable idle and load temps for a non-OCed Duron?
2. Does it matter if small amounts of the thermal compound gets on the parts of the CPU other then the die?
3. The Duron die is pink. Is it supposed to be like that or is it some sort of layer that I'm supposed to remove?
Thanks in advanced - Ashura
