- Aug 27, 2002
- Kent, Washington
I am considering going water cooling some day, and one of the things that I want to do is use the dye-lite to make the water glow. Everything I read says that you are supposed to use a black light to make it glow. Well, I just saw this on koolance.com:
So, will using a blue ccfl really work to make it glow? If so, will it work a good as a uv?
Dye-Lite is a popular liquid dye which fluoresces under UV or blue light, normally used in leak detection. Coming this fall, Koolance will add Dye-Lite to the original coolant solution for PC systems. To take advantage of this effect, you will need blue or UV neon lighting in the system
