XP:
Disabling that auto-update (nagging you that you don't have a/v, firewall etc
Disabling the Service is one option, another is to just disable the AV and Firewall alerts from within the Security Center (Start | Run | Type
wscui.cpl, and click OK) | Click the "Change the way Security Center alerts me" link | Uncheck "Virus Protection" and "Firewall" in the Alert Settings dialog.
The various IE nags (getting rid of the activex warning for good, etc)
Open IE | Internet Properties | "Security" tab | Internet zone--> "Custom level" button | Downloads--> Enable "Automatic prompting for file downloads". Regarding the script warning... "Internet" zone--> Custom level" button | Scripting--> Enable "Allow websites to prompt for information using scripted windows". See also:
Disabling the Information Bar in Internet Explorer
http://www.sanx.org/tipShow.asp?index=313
Windows firewall
The following command line will disable SP2's firewall (must be run after SP2 is installed, and at least one reboot is done)...
netsh.exe firewall set opmode mode=disable profile=all
If you want to disable the firewall service as well, run this command line (do not remove the space after
start=)...
sc.exe config SharedAccess start= disabled
Vista:
Disabling UAC
Start | Run | Type
msconfig, and click OK | On the "Tools" tab highlight Disable UAC, click the "Launch" button, and reboot.
Autorun
This can be disabled via Control Panel | AutoPlay
Also the nagging about not having a/v
Control Panel | Security Center | "Change the way Security Center alerts me" link | Click the "Don't notify me and don't display the icon (Not recommended)" button.
