So I recently built a brand new rig (in sig) and I purchased 2 GTX 580 DS SC on impulse cause it was on sale. Once I had it set up, and did some testing with Crysis 2 with all the eye candy add-on packs + DX11 + Ultra settings, I noticed it running quite hot (for a dual fan set-up).. I did some observations from the case while running the games and quickly found out that the graphics card did little to disperse heat from the usual back vents, what it did mostly was dispersed it's heat into the case from the sides of the vents of the brackets.
Now before I have to go through the trouble of returning the cards, I was wondering how well will repositioning my case fans to divert the heat generated from the cards going into the case will work. I made a diagram of my current airflow and modified.
Current:
Top : 1x 230mm fan
Side : 1x 230mm fan
Front : 1x 230mm fan
Rear : 2x 120mm fans (Corsair H80 setup)
Modified Target:
Top : 2x 120mm fan
Side : 4x 120mm fan
Top Front (Drive Bay) : 1x 120mm fan
Bottom Front (HDD Bay) : 1x 230mm fan
With the modified, I am wondering if replacing the 230mm fans with 120mm fans will contribute to getting more air in the case or not. I would like some inputs as to what are some good performing 120mm case fans if I do plan on going with the modified route, noise isn't too much of a problem for me but if it is possible to have lower noise and good performance in the fan, I'll take it. Otherwise I usually take priority over performance/cooling over noise level. Also hoping with this route it would actually help with the overall case temperature.
I purchased the 2 cards for about $419.99 each and spending a bit on some which is alot cheaper than most 580s out there, and if I must return them they also charge a 15% restocking fee, so I would like to avoid returning them if possible. I do not mind spending a bit extra on the fans for the case so there isn't really a budget on the fans. Other suggestions are also greatly appreciated.
Thanks.
Current:
Top : 1x 230mm fan
Side : 1x 230mm fan
Modified Target:
Top : 2x 120mm fan
Side : 4x 120mm fan
Thanks.
