If you can figure out how to mount it, then yes... beware of voltage issues as I'm sure that larger fan won't run well (if at all) from the power plug on the card itself; you will probably need to use a fan connector on your motherboard...
I have the same card, simply remove the stock fan and replace it with a Sunon or similiar 40x40x20 mill fan.....Superglue or Silicone adhesive is the way to affix it. Or use four rubber washers(to get adequate clearance if you 'stack' it) and affix the 40x40x20 mill fan on top of the stock fan..
