Not quite sure if this is the right forum to post this in, but here's my dilemma:
I'm using a Geforce 980 Ti graphics card that is installed in a watercooling loop. I had a small leak in my loop that seems to have dripped a bit of coolant onto the graphics card.
This happened while I was asleep. When I woke up, the computer had turned itself off. I didn't notice any leak at first, so I turned on my computer, and when Windows was supposed to boot up, I only got a black screen.
The bios screens all worked fine though.
Then I noticed a small puddle of coolant on the backplate of my graphics card. So I took everything apart and cleaned the graphics card.
There was a few drops here or there, but the leak was extremely minor it seems. I cleaned it fairly well, put it back together and reinstalled it.
But the same thing is happening. If I boot into safe mode and unintall the Nvidia drivers, I can boot into Windows in low-resolution 640x480 at 60hz. But whenever I try to install Nvidia drivers, the screen will become pixelated, then go black. Then I cannot boot into Windows anymore unless I go into safe mode again and uninstall the drivers.
Is there any way to salvage this card? I could disassemble it and let it dry for longer, possibly as long as 24 hours to see if that might help.
I do have it under warranty from EVGA so replacement is an option. I really need this computer for work though so going without for a week or so is not an ideal solution.
When I inspected the card, I really didn't see much evidence of coolant leaks at all. The card itself looked quite good and dry.
Please advise on how I might be able to salvage this card and avoid having to send it for replacement.
Thanks!
Thanks!
