- Nov 19, 2005
If you have 2 monitors you should buy an X800GTO2 with two DVI connectors and you should use the lcd as your editing screen and your crt as your previewing screen.
larva said:You just supplied the proof yourself, thanks for not making me chase it down. Notice the 930 is outperforming the Opty 165 by nearly 20% in the link you showed... Heaven forbid we should try a 940.
And this test is obviously not utilizing multiple threads efficiently, or the 3800+ would get smoked. Toss a 670 in there and it would wipe the floor in this (fairly non-representative) test. As pointed out earlier that software is outdated, and you will find that the current stuff will increase the lead of the Intel processors.
And bear in mind that raw CPU power alone is not the factor that drives serious video editing to Intel. It's the chipsets, folks. I know you've grown so used to the nature of Via, Sis and Nvidia chipsets that you don't see this as a factor, but try to produce sizeable quantities of truly high-quality video cost-effectively day-in and day-out and you will.
Just thank your lucky stars you at least have Nividia, I am fully aware that they are better than Via and Sis. They are still not equal to Intel chipsets, especially in serious video editing applications.
hitbyaprkedcar7 said:Would you guys recomend water cooling or the VapoChill cpu cooler ? http://www.frozencpu.com/ex-blc-217.html would i have to change the fluid inside the cooler? what gives you better temps
hitbyaprkedcar7 said:yeah i figured that but since i already had one going, and people knew what i was trying to do, it might be easier to ask here. ill go make a thread over there though
What are the main differences between the Opty 165 and 170 ? Besides the opty has a 10x multiplier and the 170 has a 11x ? Does that mean i could get more out of the 170?
greenmaji said:The Vapo should whip water cooling but the price diffence really can be rediuclus.. Not to mention the other hazards of running such equipment. Or the fact that if you really dug deep and read alot about it the Vapo units could be built for half the price they sell for or less. It's your call really but I really dont see the need unless your planing on benching this thing.
greenmaji said:When it comes to the 165 or 170 if your going to be investing in 1Gig sticks (they are tougher to get higher FSB or HTT whatever you want to call it these days.. LOL) of ram it will be alot easier to get a CPU with a higher multiplyer (the 170) if you plan on overclocking it now or later. (psst.. this is a little secret.. dividers really don't effect AMD procs. perfomance, HTT and FSB of your memory really doesnt matter if you dont plan on running it 1:1, wich you really dont have to.)
Michael Warren said:If you have 2 monitors you should buy an X800GTO2 with two DVI connectors and you should use the lcd as your editing screen and your crt as your previewing screen.
