Hello, all. This is my near final list of desired parts for my new desktop. Primary purpose would be for gaming. This is my first time building a PC so I don’t know all too much about it, but I did leave OC and Crossfire options open…I think. But yeah, critique my build, let me know if I could go better on some spots or if things aren’t compatible. I have some questions at the end of the list
Motherboard - $159.99
ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131296
Processor - $169.99
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
Video Card - $289.99
POWERCOLOR AX4870 512MD5-PPH Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131117
RAM - $87.00
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145194
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220269
Hard Drive - $59.99
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
Processor Cooler - $34.99
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003&Tpk=xigmatek S1283
Processor Cooler Bracket
XIGMATEK ACK-I7751 Retention Bracket - $6.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
Thermal Compound
ARCTIC COOLING MX-2 Thermal Compound - $6.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
Power Supply - $119.99
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V NVIDIA SLI Ready ATI CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
DVD Drive - $23.99
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106263
Case - $84.99
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
OS
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Total - $1144.89 ~ $1145.00
Questions:
1. Does the manufacturer of the parts have any effect of the compatibility of the parts? Are certain manufactures known for better quality and effectiveness? If so, are there any in my list that I should stay away from?
2. I have three different RAM listed. I’m pretty sure the last two would be better than the first because of their better timings (the #-#-#-#). Which one would you recommend?
3. Are there any tips on getting good deals through Newegg? I know they have the rebates… Do they actually work? Would it be foolish to calculate my total cost after all rebates? I know they have special offers at certain times, but other than waiting for said offers… are there any other ways I could save some bucks?
4. Case(sigh). I’m torn between a couple of cases. I want it to be somewhat quiet. Of course, I want it to have adequate cooling/temp and obviously have it be able to fit all my parts. I was thinking Antec 900(scared of possible noise), Coolermaster RC-690, and also, on the expensive side Coolermaster Cosmos 1000(Reviews say it’s big and quiet). What would you all recommend?
5. Monitors. I’m building this new PC from scratch and I will also need a monitor. I’m looking in the area of 20’’ – 24’’. Does 22’’ plus stretch your games out if they don’t support the aspect ratio? I think most games are 4:3 aspect ratio, but sometimes offer it for 16:10, which is what I think the big monitors use. I would like to have a 22’’ or 24’’ monitor, but I don’t want to worry about the game being stretched out. (Games I want to play at max settings are some FPS like GoW or Half Life 2, World of Warcraft, City of Heroes, Starcraft 2 and Diablo 3(when they come out), of course all at highest possible settings). Additionally, I hear that you want a sub 5 ms time. High contrast ratio 3000:1 +, and brightness around 330cd/m2. So, yeah. You guys know of any good big LCD gaming monitors
Sorry for all the questions. I’m really excited, almost going to order my parts, but just checking to see if everything is good to go.
Thanks in advance.
I look forward to hearing your responses,
Jeff
Processor - $169.99
RAM - $87.00
or
or
Hard Drive - $59.99
Thermal Compound
DVD Drive - $23.99
Case - $84.99
OS
Questions:
Thanks in advance.
Jeff
