The minor instability I had was cured by several small tweaks and who knows which did what?
As the temps went up yesterday the reboots kept getting closer together so I suspected an environmental problem. I rearranged the half-shell so the PSU was pointed differently and added a Scythe fan to blow across the heatpipe radiator. This rig in it's earlier incarnation had a GeminII cooler on it - not the best CPU cooler out there but
excellent for table-top rigs. With two 120mm horizontal mount fans the chipsets and RAM get some good cooling. I didn't realize just how much that meant until I stuck my finger down on the heatpipe radiator yesterday. It wasn't scorching by any means but it was too hot for my taste!
Secondly, when I built this rig I had to put the Corsair RAM in the 'B' slots because of their height v the TRUE. This didn't bother me so much but the nearest stick still had a hair of a lean to it - the TRUE was just a tiny bit in the way. I probably could have fixed that by removing the motherboard and adjusting the TRUE's position since there is a
little bit of play in the exact mounting position, but once it's clamped down this thing won't budge a micro. Instead of going through all that I dug into my box of goodies and came up with a pair of 2x1Gb Geil DDR2-800CL4 RAM, low profile, and swapped them out for the Dominators. The Geil didn't OC
nearly as well as the Corsair but at least they fit under that monster heatsink.
As a final tweak I increased the PCIe bus to 115 MHz. When I was cranking up my 9950BE on the 790GX board increasing the PCIe (actually, the on-board video core and GDDR speed) was the only thing that let me raise the clock speed above 210 so I figured I'd throw that in for good measure.
From all that I still had to lower the CPU speed down just a little. Here are the new bench results and a copy of the baseline benches as a reference.
3000 MHz
Everest (read/write/lat) 9479/3460/18.7
SuperPi (1M/2M) 23.015/0.55.30
SETI* 3076/6990
3DMark03 3083
Aquamark 4011/14397
3774 MHz
Everest 12455/3888/15.0
SuperPi (1M/2M) 18.406/0.44.359
SETI 3856/9227
3DMark03 4123
Aquamark 3927/17910
This is at 1.25 vddNB under SETI load and unless something radical happens it'll be my last tweak until it's under water:
