- Feb 20, 2007
Ok guys, first WC project is completed! Still needs ALOT of tweaking, but all of the basic constuction/assembly is done.
Full system is Q6600, P5K dlx, 8800 GTS G92, 2 X 1 gb mushkin PC8500, Corsair 520hx, 2 X 320gb 7200.10 in RAID 0.
Cooling is: D-tek FuZion with washer and quad accelerator nozzle, MCW60 + DD Fatboys + swifttech ramsinks, PA 120.3 + EK G3/8 barbs, D5 vario, Micro-Res + DD Fatboy barbs, Tygon 7/16ID 3/8OD
I have some temp issues though.....
Ambient is 24c
CPU idle is 44/44/42/42 (Q6600 9 X 400 for 3.6Ghz), and load with P95 small FFT is 68/68/63/63 at 1.46 Vcore in BIOS.
Thats the same as my TRUE 120 on my other case which I felt was a sweatbox.
GPU idle is 40C (8800 GTS G92) and load is 45C. Clocks are 800/2000/1100.
These temps are WAY too high IMH
I have bled the system, but Im sure there could be more air bubbles somewhere. Ive turned it every which way you could possibly think of and shaken it so much my shoulders are sore LOL.....
I have new fans on the way (Yate Loon 12DH-12 from Petras) that reviewed very well on the XS fan review to replace the Antec tricools Im currently using.
I think that my Radiator mount/placement could be an issue. From top to bottom here is how it is mounted on the top of my case on the inside. RAD -> Neoprene Gasket -> Fans attached with #6X1/2 inch screws -> Fans directly attached to top of case with fan case screws. Do I need a shroud to move the fans further away from the radiator? The fans are on top of the rad in a pull configuration.....would I get better results moving them to the bottom in a push config?
Also, the hole I cutout for the rad at the top of the case is less than perfect. Cosmetically it looks good since the radgrill is covering it, but I made a simple rectangle that was about 1/8inch smaller than the screw holes on the PA120.3 This leaves approximately 1/4 inch (or so..??) of fan on the periphery which is covered by the aluminum top. Is this significant?
GPU temps are ok, but I think thats likely because its a G92 and not a G80 and produces significantly less heat. I still think it should be cooler though.
Pics to follow later today! I still need a TON of wire management but didnt make sense to start since Im going to be pulling out all of the fans later this week, and wanted to settle up with temps first.
Thx!!
Ambient is 24c
Thx!!
