So I finally decided to jump into water cooling. The below mentioned items are going into a ATCS-840 Case. I have already tore the case apart and had it custom powder coated. The items are going to be used to cool a EVGA x58 Classified 760 board, a i7 920 cpu, and 2 BFG GTX 275 OC cards. Here is the list I came up with so far:
Pumps:
Swiftech MCP 355 18v
Swiftech MCP655 with Speed Control
XSPC Laing DDC Top
Reservoir:
Swiftech MCRES-MICRO Rev2
T-virus Inverse Blue by Frozen-Q http://www.overclock.net/water-cooling/510025-t-virus-inverse-res-finally.html
Blocks:
EK-FB Kit EVGA x58 Classified Acetal
EK-FC275 GTX SLI - Acetal
HEATKILLER® CPU Rev3.0
Radiators:
Black Ice GTX 240
Swiftech MCR320-QP-K Triple 120mm Radiator
Fittings:
Bitspower T-block
Bitspower True Silver 1/2" Barbs
Swiftech 1/4" BSPP to 1/2" barb res port fitting
Swiftech 1/4" BSPP to 1/2" barb fill port fittings
Herbie Clips
Tubing:
Primo Flex Pro LRT UV Red
Primo Flex Pro LRT UV Blue
Silver Kill coils (02 for each loop)
Fan Control:
02 Scythe KAZE MASTER ACE 5.25" Bay Fan Controller - Black
Fans:
Antec Tri Cool LED Fans 39 / 56 / 79 CFM 25 / 28 / 30 dBA
I plan to run the 360 rad for the cpu/nb/sb loop and the 240 rad for the two BFG GTX 275 cards. The reason I chose the MCR320 rad was for cost to efficiency. I went with the Black Ice rad because I would like to avoid using a 320 Rad in the lower end of the ATCS case. It already has mounting options for 2x120 fans.
The two pump choice was based on the following: MCP 655 for video cards due to low flow restriction allowing flow to provide more cooling than a high psi pump. The MCP 355 would be used for the CPU/NB/SB setup because of the higher flow restriction. Also I intend to add Ram water blocks for my Dominator GT ram once Corsair puts out their new block.
I plan to run to drain lines off the reservoirs for maintenance draining purposes. The reservoir choice for the t-virus cannot be changed due to it being the focal point of the case theme. Going with a Resident Evil theme.
Any suggestions would be welcome as I am extremely new to this and can use all the help I can get.
Pumps:
XSPC Laing DDC Top
Reservoir:
Blocks:
Radiators:
Black Ice GTX 240
Fittings:
Bitspower T-block
Herbie Clips
Tubing:
Fan Control:
Fans:
