I've just recently started my new water cool project. Ordered and received most of my parts, but there is a lot of prep work to be done before it's all together. Also Waiting on the cooling parts which should arrive next week.
PC Specs:
Case: Antec Nine Hundred
CPU: AMD Phenom II X6 1090T
Mobo: Asus Crosshair IV Formula
Memory: Mushkin Ridgeback Redline 1600Mhz 2x2GB
GPU: MSI GTX 460 Hawk 1GB
PSU: Corsair 750TX
HDDs:
WD VelociRaptor 160gb (boot)
WD Black 500GB x 2
CoolinSpecs:
Pump: Swiftech MCP655
Radiator: Swiftech MCR320
CPU Block: Swiftech APOGEE XT
GPU Block: (Can't find a Full Block)
Reservoir: Swiftech MCRES Micro Rev2
Tubing: Primochill Primoflex Pro LRT UV Red
Liquid: Primochill PC Ice
Fans:
Front (3 - 120mm Antec 3 Speed Fans)
Side (Scythe Slip Stream 120mm PWM & V.R.)
Back (Scythe S-FLEX™ S-FDB 120mm Low Flow 49.0CFM)
Top (200mm Antec 3 speed)
Radiator (3 - Scythe S-FLEX™ S-FDB 120mm Low Flow)
Intake Fans have Filters (Silverstone FF121B 120mm Fan Filter)
I'll be Overclocking the CPU to around 4.0Ghz+ and seeing what I can get out of a GPU with a good air cooler on it already. I know the liquid I've chosen is not what I should be doing. Initially I wanted to just use distilled water and PT Nuke, yet I'm finding it extremely difficult to find PT Nuke. Links would be great.
I've started on the Initial prep of the case. I've cut holes for the wire routing and painted it Flat Black all around, I don't want any reflections. Might add red accents later on.
Since the Mobo and memory has a lot of Black/Red I've gone with the UV Red tubing, hope 10ft is enough. The radiator will be mounted on the back because the case has 2 holes with grommets to route my tubing.
Defiantly going to have to take pics and show it during the whole process. Very Excited to see how it turns out and what everyone thinks.
PC Specs:
PSU: Corsair 750TX
HDDs:
WD Black 500GB x 2
CoolinSpecs:
Fans:
