- Nov 27, 2002
- new jersey
all from dtekcustoms.com
cpu block- polytopped spiral
rad.- pro combo w/ 120mm aluminum fan
pump- eheim 1048
res- only one on their site ^_~
tygon tubbing
and than some special things, like water dye and UV light, but now for the questions
would a chipset block help that much, if at all, and if so, what does it help? is it to make fsb ocing easier?
I plan on using these parts on a new board, when the claws come out, a dual board, would the pump be strong enough?
what advantages would the eheim 1250 have over the 1048, if any at all?
is the cpu block the best on the market?
any other tips? this is my first leep into ocing, and I wanna make sure I get a steardy base. I plan on getting all 1/2 inch fittings
thanx
pump- eheim 1048
tygon tubbing
thanx
