paulmckenna
- Feb 5, 2016
Hi All,
I'm new here, but have been working with PC's/hardware/OS's from 1990 onwards.
Have had no problems with AMD OCs in my last 2 home builds, so went for intel at XMAS build (best bang for buck, i.e., daughter started college)
HAVING REALLY PERPLEXING PROBLEMS OVERCLOCKING ABOVE 40X
GIGABYTE Z97P-D3 firmware F8
G3258
HYPER TX3 Evo cooler with extra heat sink fan (applied not as much silver paste as I should, but better than stock)
2 X 4 Corsair XMS3 DDR3 1600C11 1.50v
Cool master B500 v2 PSU
Cool master X 2 front case fans, and 1 rear fan (+psu), negative pressure in case tested
Thermaltake Versa N21 Midi Case
128 ssd & 1GB Seagate
Finely old GPU Asus AMD EAH6570 1gb (Graphics not important right now)
Windows 10 X64 clean install (Latest Update)
ALL SETTINGS WERE SET GRADUAILY.......
I can OC to 43x, only 38x vcore (can't go higher), 1.35 vcore (HIGH) voltage after REBOOT from Bios, (72c max temp both cores).
It will not boot from cold, sometimes bios screen freezes or windows will give various errors,
but when rebooted after BIOS changes, passes the AIDA64 stress test (not that stressful).
This is all the way down to 41x 38vc and slightly lower vcore voltages. 40x is the only setting that is stable after shutdown & reboot.
I have changed various "AUTO" BIOS settings, XMP, K-CPU, Turbo settings Disabled. VRIN set to normal etc.
I HAVE NOT "messed" with ANY other voltage settings though.
When at 41x or above and bios freezes/won't boot, removing 1 of the memory modules allows me to boot and enter bios again. WEIRD.
I would love to get 4.3x (1000ghz above stock), can't understand why I can't get the vcore above 38x (not the end of the world though).
Sorry for the all the hassle, and to me all of the above does NOT make sense to me from my experience. All I can surmise is that I have a
crap mix of hardware/MB. And/or have got the WORST Intel G3258 in history.....????????????
All comments would be appreciated with details, however obvious....................Thanks
G3258
