- Dec 1, 2010
- Doylestown, Ohio
But then you need to pedal with more force.
I think you need to hook it up and try it.
Hook it up and try to see how long you can run a 75 watt light bulb before you put your computer at risk....
It would work just fine. Just don't go over the specified charging amperage.
BTW, a permanent magnet alternator would be more efficient.
The higher ac voltage out from the inverter will travel longer distances better than the 12V supply that goes to the inverter. Inverters need pretty heavy cable to supply the amperage drawn at 12V.
So: short thick cable from batteries to inverter and use a longer cord to your 110VAc device. There is still some loss on the a/c 110 cable, but is not as noticable.
Leave the inverter at the batteries, then route a separate DC line for voltage monitoring. Plain CAT5 works if you only need a few mA.Thanks! Hmmm, I need the inverter in my room so I can hear the low battery alarm in case the batteries get low overnight...
I may have to fish that thick old wire up to my room.. Ugh. Hard to work with when it's as stiff bricks.
you could try your proof of concept using a small inverter. I would get a small one to try things out. Make sure that your ideas are going to work before you spend all your $$$.
That's pretty much what you do. Or to be more accurate, use an actual charge meter circuit.Hmmm. Go on, I've never thought of this! Run cheap cat5 (or standard 14/2 because we have 2 rolls of it) then what? Hook an volt meter to it?
ok youve had long enough lets see the pics and lets see this thing working
