- Sep 4, 2011
- Lives under a bridge
gpu3 linux NEED HELP (NOT SOLVED)
NOT SOLVED
ok I tried everything I know. but I can't still get it to work
I'm using fudnutu linux
kernel 3.8.5-1
NV driver (tried 304 and 313)
wine 1.5.25
GPU: 2 gtx 470 (stock and stable)
cuda tool kit (tried 3 4 and 5)
this is the problem from the looks of things.
[14:05:37] Folding@home Core Shutdown: GPU_MEMTEST_ERROR
[14:05:41] CoreStatus = 7C (124)
[14:05:41] Client-core communications error: ERROR 0x7c
[14:05:41] This is a sign of more serious problems, shutting down.
any help ? it's been so long that I can't recall every thing I need to do.
NOT SOLVED
kernel 3.8.5-1
wine 1.5.25
Code:
tux@localhost fahgpu2$ wine Folding\@home-Win32-gpu.exe
Note: Please read the license agreement ([email protected] -license). Further
use of this software requires that you have read and accepted this agreement.
[00:26:01] Gpu type=3 species=20.
--- Opening Log file [April 10 00:26:01 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: Z:\home\tux\fahgpu2
Executable: Z:\home\tux\fahgpu2\[email protected]
Arguments: -verbosity 9 -forcegpu nvidia_fermi -gpu 0
[00:26:01] - Ask before connecting: No
[00:26:01] - User name: voodoo (Team 32)
[00:26:01] - User ID: 5D0535925746FF41
[00:26:01] - Machine ID: 2
[00:26:01]
[00:26:01] Loaded queue successfully.
[00:26:01]
[00:26:01] - Autosending finished units... [April 10 00:26:01 UTC]
[00:26:01] + Processing work unit
[00:26:01] Core required: FahCore_15.exe
[00:26:01] Trying to send all finished work units
[00:26:01] + No unsent completed units remaining.
[00:26:01] - Autosend completed
[00:26:01] Core found.
[00:26:01] Working on queue slot 01 [April 10 00:26:01 UTC]
[00:26:01] + Working ...
[00:26:01] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -checkpoint 3 -verbose -lifeline 37 -version 641'
[00:26:01]
[00:26:01] *------------------------------*
[00:26:01] Folding@Home GPU Core
[00:26:01] Version 2.25 (Wed May 9 17:03:01 EDT 2012)
[00:26:01] Build host AmoebaRemote
[00:26:01] Board Type NVIDIA/CUDA
[00:26:01] Core 15
[00:26:01]
[00:26:01] Window's signal control handler registered.
[00:26:01] Preparing to commence simulation
[00:26:01] - Looking at optimizations...
[00:26:01] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[00:26:01] - Created dyn
[00:26:01] - Files status OK
[00:26:01] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:26:01] - Expanded 58441 -> 259314 (decompressed 443.7 percent)
[00:26:01] Called DecompressByteArray: compressed_data_size=58441 data_size=259314, decompressed_data_size=259314 diff=0
[00:26:01] - Digital signature verified
[00:26:01]
[00:26:01] Project: 8071 (Run 81, Clone 4, Gen 140)
[00:26:01]
[00:26:01] Assembly optimizations on if available.
[00:26:01] Entering M.D.
[00:26:03] Tpr hash work/wudata_01.tpr: 223624892 2522798745 3236157214 4163646708 4239544289
[00:26:03] GPU device id=0
[00:26:03] Working on Glycine aRginine prOline Methionine Alanine Cystine Serine t= 81.00000
[00:26:03] Client config found, loading data.
[00:26:03] Finished fah_main status=59
[00:26:03] mdrun_gpu returned 59
[00:26:03] GPU memtest failure
[00:26:03]
[00:26:03] Folding@home Core Shutdown: GPU_MEMTEST_ERROR
[00:26:08] CoreStatus = 7C (124)
[00:26:08] Client-core communications error: ERROR 0x7c
[00:26:08] This is a sign of more serious problems, shutting down.
