Please help. First time here. Just built my fourth system, doesn't work as it should. Here's the situation: BRAND NEW system - mobo+cpu+RAM combo bought together, rest separates.
DFI-AK76 mobo (DDR 266FSB etc)
AMD 1.33G 266FSB cpu (AYHJA)
Tai-sol heat sink (CGK742092)
Sparkle 350W PS
256 MB PC2100 DDR RAM
ATI Radeon 64 M video
IBM 40G 7200 HD
Plextor 16/10/40
(I have removed all other cards etc.)
Dual boot WinME and Win2K sp2
On first assembly, could not complete installation of Win2K, Win98 or ME at all (random errors, BSD etc). Then turned off all internal caches in BIOS, took 3 hrs, but installed win98 (later upgraded to ME and dual boot with win2K). I then turned on caches, tried optimized/fail safe/normal defaults in BIOS, errors again. Cleared CMOS, flashed to latest BIOS, replaced RAM with a new stick (Kingston), changed video card to an ATI Expert 8 MB, still crashes, reboots, BSD etc, at random. I then did what the manual says I shouldn't, changed the mobo CPU-FSB jumpers from 133MHz (266DDR)to 100MHz (200MHzDDR), which is the mobo default. The dip switches SW1 and SW2 are on auto setting. BINGO! Everything works! However, the cpu is underclocked at 1.0GHz. Careful exam of the cpu reveals it is indeed a 1.33GHz AYHJA chip. So why won't it run at 1.33? I then looked at the cpu voltage and temps. Here's the problem, as I see it:
With jumper at 100MHz (200DDR):
Core temp steady at 35 for several hrs.
Vcore = 1.77
2.5V = 2.58
3.3 = 3.3
5V = 5.07
12V = 11.82
With jumper at 133MHZ (266DDR):
core temp shoots up to 50 within 5 mts in the BIOS screen, I shut the thing off.
Vcore = 1.78
2.5V = 2.58
3.3 = 3.28
5V = 5.05
12V = 11.88
I checked the HS and cpu, the thermal paste is dry, there doesn't seem to be anything between the HS and cpu core. The placement however, is OK (removed and replaced it myself - carefully!), and the HSF works normally.
So, why doesn't the system work the way it should? Is it the heat? Why should the system not run even if the cpu is say at 50 or 55? Why does the cpu heat up so much in an AC room with the case open, case fans blowing away (I have an extra), heatsink of reasonable quality, good power supply, and all settings as they should be. Does the thermal paste make such a difference? If so, why does everything work so well for hours in the underclocked state? Please help, I am going crazy. And sorry for this lengthy post.
Sparkle 350W PS
IBM 40G 7200 HD
Plextor 16/10/40
Vcore = 1.77
2.5V = 2.58
3.3 = 3.3
5V = 5.07
12V = 11.82
Vcore = 1.78
2.5V = 2.58
3.3 = 3.28
5V = 5.05
12V = 11.88
