- Nov 24, 2003
- Netherlands, Almere
Hi All,
I’m looking for a centrifugal blower 12v DC, something like :http://www.ebmpapst.us/allpdfs/G2G097.pdf
"max 120mm diameter", with “no” dBA (virtual silent) and a large as possible CFM.
The total dimensions must be around 150x150x150mm (incl. motor, preferably the motor is placed “inside the rotor” to save space, and to get a bigger performance.)
I tried just about every electronics shop in the Netherlands, as I understood that these kinds of blowers are used there.., but no one can seem to help me with it. .
One problem might be is that the intake can only be from one side. (it needs to suck air through a radiator), and then blow it through an other one.
A lot of blowers I can find on the internet (manufacturers) have on 2 sides an intake. But I guess I can work around that with a special kind of “duct’
The blower has to be at least 75 cfm, preferably more, but as long as it is SILENT at 75 cfm. (No problems to adjust the voltage)
Standard fans are no problem to find, I have enough PAPST fans (12cm, 8cm etc) but they just can’t give the pressure needed, or if they can, they are sure not silent!
I’ve been thinking to use the blower of a car (I bought me a used one from a car dump), but my problem there is that the only have a 50 mm rotor (diameter 148 mm) and the rest is 120 mm for the motor. That’s for me a sure waist of space.
I cleaned the used blower with WD40, and it was silent for about 8 hrs, no it starts to make a constant whirl. One other problem with the car ones, is that they don’t have a housing..
I’ve been looking for about 2 weeks now, and I’m unable to find one. I’m getting quite desperate.
This is the setup I want to make. http://members.chello.nl/l.vanderhorst1/rad+blower.JPG
I want to build this in the top of a http://directron.com/da10bd.html case.
In the bottom, there will be on other rad, at the intake.
Some of you might feel that it is overkill to place that much radiators, but well, I want to keep it as cool as possible, and I’m planning on watercooling just about all that gets hot.
My blower will be, aside from the PSU, the only thing that will be moving air.
Help me out here! Where can I buy a good blower?
