- Oct 29, 2010
- Loveland, CO, USA
Hey guys, been awhile. Figured I should do some visiting while I am doing upgrades to my old workhorse I build some years back. Use to spend alot of hours playing around with this overclocking. But as life would have it, when other things come in, invariably some stuff must leave. But revisiting is always nice and maybe a tip or 2 on my rebuild will help.
So, what I have is the new motherboard which is actually being put into a new LIAN LI PC-Z60 case I've had setting here for a few years. Decided I didn't want to keep the HUGE Obsidian any longer as it is taking up too much room in my basement home theater I am trying to get finished before too long. Anyways, it's a very nice box, all aluminum so it's nice and light. My 6 HD RAID10 fits in nice and so does my 120 Black Ice Rad in the rear. Unfortunately, there isn't any room for my Black Ice 360 Rad anyplace. So, I am loosing 3/4 of my cooling capabilities I figure. I'm not overly concerned as I am not really going to need to overclock to GHz like I did in the Obsidian box, but I still do video editing, so I do need some reasonable amounts of extra cycles from my FX-8350 CPU.
Everything is together and work well. I have done some moderate overclocking and have it stable at 4.640 GHz right now. This could be fine except I am a bit hotter then I like at 64° top running Prime 95 for over an hour or so. I'm in air conditioning, so I don't expect that will change much by itself. But, I really would like to be in the sub 60° range if possible. So, my first questions is, is it possible to do this with a single 120 Rad (push/pull) and and EK CPU water block? I have Koolence RP-401x2 dual pump/reservoir moving 1.7 GPM of water, which I feel is more then enough. But, I am only getting around .5° C difference under extreme load between inlet and outlet water from the rad. Seems to me it use to be greater, but just don't remember. The maximum water temp I have seen so far is just over 40° C. It may be that just a single 120 Rad isn't going to do any better, don't know.
Well, I'll keep with it for a while longer. If anyone has some ideas, please let me know.
Take care.
-Rodger
Take care.
-Rodger
