- Mar 16, 2011
I'm sorry this is my first post, I would spoiler tag the pics but couldn't find the button.
I simply can't find an instructional vid/article that pertains to the issue i'm having. I know OP's need ot be detailed so here it goes.
EDIT: am trying to fix the pictures, i failed at linking the first time
Also running an NVIDIA GeForce 7900 GS (450mhz core, 660mhz mem, 256 Mbytes, buswidth 256)
The Problem:
I don't know how to even begin overclocking my processor, though i've been told it usually responds ridiculously well to overclocking. Im running an ExtremePower 550W source with like 6 fans in my tower so i dont think heat will be a problem. I have 8 gigs of DDR2ram (planning on upgrading to windows 7 soon, only on windows xp-32, i know 5 g's of ram is going unused)
I've been trying to go through YouTube instructional videos but the BIOS for each is different (and theyre all different from mine). Here are screenies of my BIOS:
Uploaded with ImageShack.us
Things i've tried are:
Under Advanced -> JumperFree Config. there are 2 plausible options. One is "Manual". The other is shown "AI Overclock". Manual settings allow me to manually change any frequency controls (also shown). "AI overclock" gives preset options.
I was unable to find anything "useful" about the "CPU CONFIG." sub-menu.
I have tried two things, both of which resulted in (after saving settings and exiting BIOS, thus causing my computer to restart) my computer attempting to boot up (i hear one beep), then failing to do so. I have tried setting the "AI overclock" to settings such as 10% and 20%, and I have also tried manually changing my FSB Speed to 1200.
My monitor is digital and will show "no signal" if it is not connected to my tower. However, upon attempting to boot up after these various modifications, my monitor will appear to have input (as indicated by an indicator light) but will be completely dark.
Can ANYBODY PLEASE give me step-by-step instruction on how to OC my machine??? I know it can give me more grunt, but so far all my pathetic attempts have resulted in me being forced to remove the CMOS battery to reset my BIOS. My tower is shiny clean, air-sprayed and such but I DONT UNDERSTAND why i can't modify it.
Thank you SOOOO much for anyone who helps this struggling new OC enthusiast.
The Problem:
