Trying to put together a cheap simple little system, BUT having video problems...Posting on a couple of forums hoping someone may have had this issues before...
System is as follows:
CPU - AMD A4-3400 Llano 2.7GHz Socket FM1 APU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106014
MB - MSI A55M-P33 FM1 AMD A55 (Hudson D2) Micro ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130641
RAM - - 4GB (2x2GB) Corsair XMS3 DDR3 1600MHz
PS - Corsair 430w
DVD - LG
HD - Western Digital 120 GB 2.5" 5400 rpm
Installed:
(this is the 3rd attempt for windows 7, before I didn't do all the updates and was hoping that might have caused a problem)
1) Windows 7 then WIN 7 SP1
2) ethernet driver (from CD)
3) then download all windows updates (like 30 restarts later)
4) installed chipset drivers (from CD, restart)
5) right click update display adapter, let it download automatically
--> on restart BLACK SCREEN, shows the windows logo "starting windows", you can see it turn blue with the welcome then it turns to BLACK screen and there is no image.
This will also happen if you install AMD catalyst Suite 12.8.
Everything will run until you update the graphics driver to recognize the 6410D, on restart you get a black scree with no video signal, everything else seems to be still running. Tried connecting both VGA, DVI and DVI to HDMI
It will boot into safe mode, if I uninstall the graphics card driver it will boot back into windows and have signal again. But updating the driver will cause the black screen on restart (or blue screen on DVI to HDMI cable). The default display driver that loads with windows 7 will work, but its generic so no performance, i.e. windows graphics score = 1.0; right now under device manager it is listed as "other device" "Video Controller (VGA compatible)"
I tried:
- AMD Catalyst Display Driver, Win 7 64-bit, vr. 12.6 and 12.1 = black screen
- Updated to the latest BIOS v1.6 - 08/31/2012, tried AMD Catalyst vr. 12.8 = black screen on restart
- 24" widescreen and a 17" standard screen, different VGA cables, DVI to HDMI = black screen
- 1 stick of RAM vs 2; different RAM from my working computer
- Different known good 700w power supply
- I tried disabling windows AERO and went to basic setting, it did boot, saw the blue welcome screen and then the screen went black as I saw the desktop.
I don't have any video cards at the moment to try...
Seems like some sort of driver conflict, but at this point I'm running out of ideas...
Any thoughts would be great!
PS - Corsair 430w
DVD - LG
Installed:
I tried:
