- Dec 1, 2004
Hi everyone, hopefully one of you can help me with my problem. I have an Athlon xp mobile 2400, Biostar M7NCD-Pro mobo, 512 stick of Mushkin DDR, older power supply, 3 hard drives (really old 13 gig maxtor for OS, and 2 80 gig WD), and a toshiba DVD-r drive. No matter what settings I use in the motherboard setup (bios? cant remember the right term) I cannot get it past about 1200 mhz. Ive tried everything. It will go with a 200 mhz fsb and a 6 multiplier, or it will do 133 fsb with 9 multiplier, etc. No matter what combination of multipliers and fsb speeds I choose, 1200 seems to be the limit. I tried 10 multiplier and 100 mhz fsb, and wouldnt boot. Wth some of the settings above 1200 mhz, it will almost start windows. (After boot screen I see desktop for about 2 seconds, then locks) Ive played with the voltage going to the processor, everything from 1.65 volts to 1.8 volts. Any suggestions? I havent done a bios update yet, also in default mode the processor shows up as a 600 mhz. Thanks in advance.
