- Jan 2, 2003
- Nebraska USA
Ok in about a month or so Ill be able to build a new PC of my dreams, Id like to keep is in the 2000-3500 range so help me out as I'm out of the loop with some stuff.... Going to go with a Intel build I believe, since I've read so much about how good they are.... going to use my existing case Cooler Master Haf 932 w/ a red & black theme & wc basics already in my possession.
CPU - Intel Core i7-2600K Sandy Bridge 3.4GHz $314 Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
CPU Waterblock EK-Supreme HF - Full Nickel - Rev 2 $89 Sidewinder
http://www.sidewindercomputers.com/ekwaekhffuni.html
Motherboard - ASUS Maximus IV Extreme-Z LGA Z68 $359 Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
http://usa.asus.com/Motherboards/Intel_Socket_1155/Maximus_IV_ExtremeZ/#specifications
Ram - Mushkin Enhanced Redline 8GB 2133 (X2 for 16gigs total) $134(X2 $269) Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226200
GPU - do I get a 6970 or try and find a 6990 or go Nvidia ? I got like the Evga's 580/590 that come with a water block on them already. Remember I will have to get a water block for also so need that advice too. I got no idea what the best is no a days... It has to be a good step up from the 4870x2 I got now.
Sound Card - Will use existing Asus Xonar DX2 as I love it.
SSD - OCZ Vertex 3 Series 120GB $284 Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227714
main hd, I need some advice here, not sure about SSD's at all...
Storrage HD - WD TB HD $69 Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136828
PSU - ENERMAX MAXREVO Series EMR1350EWT 1350W $299 Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194092
Any advice is welcomed, about parts I have listed or something you may think is a better choice.
