- Mar 3, 2007
That's sweet! Plenty of room, eh?
My PC-V1010 is in transit!!! Yippeee!!!!!!!!!!!!!!!!!
Thanks dude & congratulations! post some pics when you get it going.
Finally, some rough pics. I still plan on cleaning up some of the wiring...
Front/Back:
With and w/o the PCI Vent Fan:
I added a Front HD Bay, and cut-away the restrictive aluminum in front of the HD Bay's fan to allow maximum airflow and removed the air filter screen (I clean my case often). I also painted the aluminum-colored parts that were visible through the front with flat black paint, and added a separate red HD LED for my RAID-5 array (in the upper right hole of the front HD Bay - pretty inconspicuous unless it is lit ). I plan on painting the bottom fan bracket flat black very soon (you can clearly see it through the front grille in the pics - it is bright silver!).
I also added the 120mm Rear PCI Vent Fan, and replaced ALL 120mm fans with those new 120mm Scythe Slipstrem fans (with the small center hub and sleeved wires). I used the 1200RPM models for Front/Mid/Exhaust, and used the 1600RPM for the CPU. I left the Lian-Li 140mm fan in the bottom intake - it is fine for the bottom compartment.
Then, I added the HR-05-IFX Northbridge cooler w/80mm fan and the SLF-1 Southbridge cooler. MAN - getting the stock sinks off the Maximus Formula was S-C-A-R-Y!!!!!! I had to fight with it for a while, and all of the sudden, "SNAP" - it popped off (and shortened my life a few hours I'm sure!). The new setup cools the NB/SB substantially better (5*-10*) and I just feel better about these temps ...
The crappy thing is as I was cleaning out the PC for these pics, somehow I lost one of my 1TB 7200.11 HD's. It is now DEAD! It freezes the system when connected in the array or connected as a solo drive to the ICH9R . I RMA'd it and I already have a replacement on the way from mwave ($189 shipped!). I sync'ed my NAS earlier today, so I just mapped my NAS's folders to replace my local RAID array!!! My PC doesn't know the difference (Bit Torrent, iTunes and all are chugging along just fine). I love being backed-up ...
PS - Yahonmaizosz - I measure exactly 9.25" from the rear of the case to the 2nd HD Bay. My PC Power & Cooling Silencer 610 has plenty of room. If you needed to, you could probably remove the 2nd HD Bay to allow ANY PSU to fit in there with ease. That would still leave 3 HD Bays down low and plenty of 5.25" Bays up front for further HD's...
Rock and Roll!
PC-V1010 Mid Tower - New Design! (I like the 120mm Chipset cooler):
http://www.lian-li.com/v2/en/product...ndex=62&g=spec
