- Nov 12, 2011
I'm thinking of adding these parts into my current build:
However the 600$ price tag is a bit too much for me. Can you suggest alternatives that would lower the price? Also I'm not 100% sure these parts are compatible (kind of a newb at picking parts).
I plan on running 1 gpu for gaming. Its a 7870 xt with two 6 pin connections.
What do I want in my parts?
case: ease of access and not having to rip metal apart in order to build the pc. I prefer a mid atx or full atx box.
mobo: ability to overclock and run 1 gpu. Good company to back up the product.
processor: ability to overclock and be under 250$.
psu: ability to run 1 high end gpu plus all the other normal stuff.
cooling: air cooling is acceptable to me. I think I read that you can use hyper 212 on the 1150 socket even though its not specificed to be able to do so on the specifications of the evo 212 for instance. However I'm unsure of which exact model I should pick for this and how simple it is to install since its not meant for 1150 socket.
The ideal price tag would be under 500$.
