Don't combat immorality with more immorality. I would go to CC and explain the situation to them. Just because you got screwed doesn't mean should try to screw someone else. Best that that 9600XT ends up where it belongs; in a 9600XT box.Tb0y said:dam. i guess i just have to buy one from frys and swap it..usually those kind of things work there. wish me luck
Goateh said:Oh .. my.. god...
How the hell can people make mistakes like that
Sniper_83 said:It is very posible that it was returned in such fasshion but I fear you may not be able to return it if you sent in for the rebate because you usually have to send that ...what the hell is it called.... bar code part.
