I just setup an old socket A system, m running an MSI K7T266 Pro2-A with an XP Mobile 2000+ chip, seeing as the multipliers on mobile chips are always unlocked I tried changing it in the BIOS, CPU-Z reports the multiplier as 12.5 stock but even If I change it to say 8x or 14x in the BIOS it still reports it as 12.5. Could it be that this XP-M is multiplier locked and does anyone know whether the pencil mod on the L1 Bridges will do the trick.
BTW does anyone have experience with the motherboard I'm using, do you know if it has PCI/AGP locks and whether they're enabled as stock, if not how can they be enabled, I'm very concerned about corrupting the HD's as I have a lot of movies etc that have not been backed up.
thanks
edit -
Heres CPU Info
thanks
edit -
Heres CPU Info
