- Apr 26, 2002
- Brisbane, Australia
Hey guys
I was hoping to get some help from your infinite wisdom to try to get a volt mod for my mobo. It is an a7v133c on kt133a.
During my overclocking experiences I have seen that my cpu stops at 1728 on fsb of 157, then only goes up 1mhz on 158. Correct me if I am wrong but this sounds like I don't have enough voltage, it is currently on 1.85. The cpu is an xp1700 agoga-4.
I haven't unlocked the multiplier so I haven't been able to test true top speed. However I think my temps are good enough, 36 idle, 39 full load and it is winter where I live so it helps even more.
That and my memory was able to go up to 156 cas2, and was faultless at 157 cas3.Note: using sdram.
Any help would be very much appreciated and I will try to respond to any replies
Oh yeah I was thinking about taking out all my pci cards to try and see if they are holding me back at all, have soundblaster, lan card, modem.
Thanks in Advance, Benno.
