- Mar 18, 2003
- Toronto, Canada
Help please! Download corruption/failed hash while 100% CPU usage. OK when idling.
When I am testing for stability using orthos or prime (or anything else that makes my computer use 100% CPU) I get data corruption with download programs like eMule, Azureus and uTorrent. When the actual download finishes at 100% the file is perfectly fine (I guess the hash checking does it's job really well). It is only DURING the actual download that I get massive corruption leading to downloads taking 3 times longer than usual due to the amount of corrupted data that needs to be re-downloaded. The programs actually ban IP addresses because of this.
I only start getting corruption if I go above ~710 FSB. At stock setting everything is perfectly fine. I get this even when using settings that are orthos-tested for over 15 hours. No BSOD, no erratic crashes. Everything works great.
I use a ATA-100 western digital 120 GB drive for my eMule temporary files storage and even with that program saving to that drive I still get corruption (but nowhere nearly as much as with bittorent programs). I'm getting another motherboard in a few days so I'll see if it's the mobo's fault.
I would greatly appreciate any input!!!
My setup:
Asus P5N32-SLI Deluxe
Pentium D 805 (overclocked to 730*20 @ 1.525 V)
Corsair Twin2x 2048-6400 (5-5-5-18-22-2T @ 1.95 V)
2x eVGA 7900 GT KO Superclocked (factory settings)
RAID 0 - 2x "Seagate Barracuda 320 GB 7200.10" model: "ST3320620AS" (Note: the RAID drive is my primary boot/windows drive and uses SATA channels 1 and 2)
Cooling:
Corsair H20 220 Apex Ultra
2x Danger Den Koosah (one for each video card)
Temperatures under full load:
CPU: 42-45 celcius (45 on a 30 degree day with high humidity)
Northbridge: 34-35
GPU:
44/43 not running graphics
51/49 running "real-time HDR demo"
My setup:
Cooling:
Northbridge: 34-35
GPU:
