- Oct 2, 2010
Hey everyone. So ever since I bought my galaxy gtx 470 I have been itching to do a full water cooling build for several reasons. I want to oc the card like crazy, cool my q6600, and basically have a dead/near silent pc.
At the moment I have a lian-li v1010b which is an awesome case from performance-pc's, which I paid enough for as is, but the cooling in it sucks and it doesn't have room for a quad rad. I know, I know, you're probably thinking, wtf? Why not just put a triple rad in that awesome case!
Well, I'm still considering it, but I saw the 800d online with a quad rad inside and it's pure win.
Here's the link to the guys full build of the case, which is what I would like to go for.
Aside from selling the case to my bro for 100 or so, if that, if I keep the case and skip the 800d what sort of WC mods can I do to it? The top can fit a triple rad no problem but the case is so shallow that even with a thin rad and a push or pull setup it will still come down over the mobo.
Currently, my setup is as follows:
q6600 w/thermalright ultra 120 oc'd to 3.2 @1.2875v with plenty of room to go, I had it at nearly 3.7 but it ran too hot for comfort.
4gigs corsair xms 6400
Corsair 620w hx
Galaxy reference 470 gtx
asus p5k deluxe wifi
Sound blaster xfi Fatality gamer
5 hdd's, +1 more sitting a box full of stuff which amounts to around 5.8 tb.
Now in the near future if and when I get the 800d I am thinking I should get a new psu, because after I get this setup water cooled, I will probably go with an i7 build shortly after, or whenever the current build starts to feel slow for games. When I do this I doubt the 620hx can handle an oc'd i7 and 470, It's running hot right now with just stock speeds and my oc'd 6600.
I am looking at a xspc 480 for the top of the 800d and probably ek blocks for the cpu and gpu. I will simply use the same cpu block for the 6600 and i7 since it's universal. It looks like I can do a push/pull config on that rad, which will make it pretty damn deep, or just put 4x120's on top to intake cold air and push it through the rad.
The key to this build for me is quietness. The xspc rad seems the best for this type of setup because the radiator fin density is very low and is ideal for low rpm fans to manage good temps, but I have read that a pull config is ideal to a push until around 12-1500 rpm's, when it doesn't matter as much. What fans are good for quietness and good performance? Are fan controllers recommended for 4-8 fans?
I can definitely use some good input on a pump to use that is silent yet powerful enough to handle a quad rad and 2 blocks. I was checking on the swiftech 350 or 355 with an ek top, and also the 655 but it looks funky to me and not sure how quiet it is. I will probably grab an ek reservoir with a tube going to the bottom of the case into the top of the pump.
As for the tubing size, this is what is frustrating me the most as there are so many possibilities. I definitely don't want the largest od tubing of 3/4, which looks retarded to me, and not the smallest either, probably something in-between. 3/8 id 5/8 od looks good I think, but not sure how good the performance would be. How about 3/8 1/2 performance wise? 7/16 5/8? Crimping is obviously a concern, but I don't think the tubing will be making any real sharp bends to just a cpu and gpu block. I will probably go with white tubing. Do you guys have any good links to show setup comparisons of different sizes?
I am looking into getting bitspower compression fittings, most likely black. Where can I get these things for cheap? Most places have them for 7-9 dollars a piece.
Lastly for the price, I figure:
120 for quad rad
120 for ek gpu block
70-80 for ek cpu
65 for pump + 40 or so for top
20-40 for reservoir
80-100 or so for fittings and tubing, with a couple kill coils.
40ish for 4-8 fans? Dont care about plain black since I will probably paint the blades white for the 800d case.
20-40 for fan controller
60 or so for quad rad grill and misc screws
240 for 800d case
200 or so for new psu, was looking at 1000w hx, but not sure if it's a good psu or if I need that much for an i7 build in the future.
So I'm looking around 1030 to 1100 for everything I figure. 4-500 for the water setup alone I don't mind, I just need to make sure I'm committed to the new case and psu for a future build, which will probably run me another 7-800 for components.
Lastly, I know the quad rad might seem a little crazy for what I'm looking at, but I want this case to last me a long time for future builds as well, so adding extra rads or pumps would be minor or not even necessary. Please let me know what you guys think, I have been researching this stuff for like a week straight non stop so any input you can give me would be much appreciated. Thanks!
Corsair 620w hx
120 for quad rad
70-80 for ek cpu
20-40 for reservoir
240 for 800d case
