I have an Intel i7-950 3.06GHz, ASUS P6X58D-e motherboard, Kingston HyperX DDR3 2000 memory, Corsair HX850 power supply and an eVGA GTX 570 video card. I have all of this in an Asus 1200 case and a Cooler Master Hyper 212+ CPU fan w/ the additional CPU fan installed too.
I am not (yet) interested in super overclocking this setup. Initially I wanted to get it setup so that my memory is clocked properly and my CPU is as close to stock clocked. I knew that with the good cooling setup that I have, I figured I should be able to overclock it at least a bit without any fear of stability/damage, but I don't have any desire to live on the edge if you get my meaning.
So I have read on many forums, read articles, etc. I am still at a loss.
I was referred to this forum post: http://vip.asus.com/forum/view.aspx..._id=1&model=P6T+Deluxe&page=1&SLanguage=en-us
It seems pretty informational. I was looking at those numbers and it doesn't seem possible to get my system setup exactly perfect. But that's not a problem. The chart for "Overclockings for Core i7 950" I at the least can do the 4th from the top where every setting is Green. My Memory is still set at DDR3-1600 (slower than I paid for) but my CPU is 3.20GHz. I was looking at the one where the BCLK was 143 and my memory was DDR3-2002, but my CPU is 3.43GHz. Do you think I should follow this? Does anyone have any recommendations?
Another guy said:
The easiest way is to set Ai Overclock Tuner to [X.M.P.], which sets initial values for:
- BCLK [143]
- CPU Ratio Setting (CPU multiplier) [21]
- DRAM Frequency [DDR3-2002]
- DRAM timings according to the the XMP profile stored in the memory modules
- DRAM Voltage [1.65V] according to the XMP profile
- QPI/DRAM Core Voltage
I wasn't able to get this setup perfectly. I don't even know what to put for QPI/DRAM Core Voltage anyhow.
Also, the detected memory timings aren't the same as what is on Kingston's website.
Any help is appreciated.
- BCLK [143]
