- Nov 25, 2009
I have read Dolk's guide to the Phenom II, and have had some success in tweaking my 965.
I am still, however, not totally straight on the NB and it's voltages.
I have also read somewhere (may be on here, may be on a different forum) that the 955 / 965 don't require as much tweaking as the other Phenom IIs with regard to the Northbridge.
I have certainly noticed a difference between a stock 2000MHz NB and a 2400MHz when running benchmarks, nothing massive, but a difference. So I am aiming to get working successfully at 2400.
My trouble seems to be when boosting the voltage of the NB to match it's multiplier, my system just doesn't seem to like the heat it creates.
Dolk's guide suggests running at 1.25v, but I "did" manage to get running at 1.175v @ 2400, although I don't seem to be able to repeat this! doh
I am under the understanding that increasing the CPU NB VID, should increase the CPU temp. Increasing the Northbridge Volt Control should increase the Northbridge on the motherboard temp. Is this correct? If so I need to think more about cooling the CPU (can't see how other than more fans or bigger case), or should I be looking to cool the NB on the motherboard in a more efficient way? Or am I fighting a losing battle with the chip being the 140tdw C2 version?
Also should I really need to worry about increasing the HT Link Freq?
