- Aug 27, 2004
- Switzerland
Well let me tell you the story. We have an internet PPPoE xDSL connection... so before we had to PC's, our main PC was connected to the modem (or router, don't know which is right for the box that plugs in directly to the phone line).
I then enabled a static IP, no problem (enabled DCHP, and all the other stuff) on the modem page. Couldn't host servers on many games.
It was configured like this-
IP adress -192.168.1.33
Subnet mask- 255.255.255.0
Gateway- 192.168.1.1 (the modem)
DNS servers I also configured well.
Then I bought my own PC, so the main connection had to be shared. A teacher at school gave me a rather old wired router to split the connection. It was perfect since the 2 PC's were not more than 5m apart, so no need for WL yet.
So I had the router was connected to the modem via main DSL, then another 2 DSL cables split up to both our PCs. This worked perfectly and we both had static IP's, no problem.
Then we moved to a different apartment. Unluckily the PC's were inevitably separated by 2 walls, like 20 meters apart. So the old router was no good.
We bought an US robotics 802.11g WL router to share the connection. Here is where everything got f****d up.
The problem with this router is that it somehow acts like another ¨modem¨. It doesn't act like a ¨dummy box¨ that just splits the connection, it pretty much took control of all the connection.
Now to connect, I have to connect first to the new router (192.168.2.1, and an IP of that gateway 192.168.2.**), then that one connects to the modem. I basically don't know how to set up the static ping right now! help!
dan
dan
