I have put a new server into use, and I'm a bit confused. I had it running with the stock cooler and the motherboard loose on the box it cam in, and that gve me temps at around 30C on idle and high 60's on load. Then I put a Coolermaster GeminII M4 on it, put it in the server case and put that in the rack cabinet. Now I suddenly see higher temps. The temp jumped straigth up when I put it on load, and it hit 90 degrees after a few minutes! That really sounds suspicious. I spread thermal grease (Coolermaster's own High Performance Compound, not the one that came with the M4) on the CPU's heat shield and also on the bottom of the cooler, scraping off most of it so it only filled the small gaps between the heatpipes and the rest of the block.
The reason I use the M4 is that I want to keep the noise down. And the one I really wanted to use, the 212 EVO, is too tall to fit inside a server case for rack mount.
Is this cooler really that bad, or have I messed up somewhere? Since the temp increases so fast (a few seconds from idle low 40's to 80 on load) I'm thinking that there is something seriuosly wrong with the contact there. I did tighten the screws all the way, as the manual for the cooler seems to say. Of course the temp would go up when the motherboard goes from being open air to inside a server case, but it really shouldn't be that bad, I think!
Edit: I should note that the room isn't hot (around 18 degrees), and while the server case is closed, there is a 120 mm fan in the PSU that removes heat and the area around the ports is open (the server case has room for a much bigger back plate than the one used in regular cases, so that is not put up there).
